  • June 19, 2025, 09:26:47 AM
Author Topic: Plywood adhesive ?  (Read 1566 times)
Offline Rob Killick
Plywood adhesive ?
« on: January 18, 2007, 03:05:10 PM »
Hi ,
What is a good way of glueing plywood bulkheads to plywood sheet ?
I'm thinking epoxy , but do I have to fuel-proof the glue joints ?
Question 2 ...
What is a good fuel-proofer for the engine compartment ?
Thanks in advance
Rob Killick , MAAC 33300
Offline Leester
Re: Plywood adhesive ?
« Reply #1 on: January 18, 2007, 03:35:39 PM »
Rob: Epoxy is the way to go on both. When fuel proofing the engine and tank compartment with epoxy heat it so it will flow and get in all the cracks etc. and is easier to spread.
Leester
ama 830538
« Reply #2 on: January 19, 2007, 07:53:06 AM »
I agree with Lee!  Epoxy for my plywood gluing.
Get some *acid* brushes to apply epoxy to the tank/engine compartment.  A hair dryer or heat gun on low and spread it around.  It doesn't take much.
« Reply #3 on: January 19, 2007, 11:54:21 AM »
Hi ,
Question 2 ...
Thanks in advance
Hello
Best thing is to  use  "SLOW CURE"  epoxy , 1 hr to 3 hour handle time  with 24 hour  setup is  best for the  bonding your wanting  to do. The epoxy has much more time to soak in and get a bite on the plywood, and when you heat most  any epoxy it will rapidly accelerate teh dry time, slow cure gives you more time to work with it
« Reply #4 on: January 20, 2007, 09:38:34 AM »
My reference to "heating" the epoxy was only for spreading it around the tank/engine compartment.   I do not heat the epoxy when I am actually gluing any parts together.  I like for the epoxy to take it's time curing in that situation  so that a maximum bond is achieved!  y1 ;D
Bill <><
« Reply #5 on: January 20, 2007, 11:03:39 AM »
Bill <><
Hi Bill
  Right you are  , Nothing wrong with  heating epoxy, I routinely do it, but that is why I recomend  slow cure, still gives time to soak in and good working time, if you heat  fast cure, it can get thick before you can even get it in place. Plus  if you heat the slow cure as  you know  , it is much easier  to spead around for fuel proofing, and  also it help the glue to soak in better when you want a good joint.
Great for  pipe tunnels , you can fuel proof the tunnel  with just a little  glue , although when I do fuel proofing i normally paint dope over the wood first to stop the raw balsa  from soaking up epoxy. That way you don't have much weight gain
Another  use  for  heated epoxy is when you  are sheeting foam components, the slow  hot epoxy is much easier to spead around and  scape off, so you get a better bond with less  glue
