  • July 13, 2025, 06:57:53 PM
Author Topic: DupliColor Acrylic Enamel Paints  (Read 2907 times)
Mike Griffin
« on: November 28, 2007, 06:11:11 PM »
Can anyone tell me if DupliColor Acrylic Enamel Color Paint is fuelproof?  If it is, after you paint your plane, do you have to topcoat it with anything to protect it?  Has anyone used it and what are the results?
Online RC Storick
Re: DupliColor Acrylic Enamel Paints
« Reply #1 on: November 28, 2007, 10:19:09 PM »
Yes and no! It is to an extent, this plane is painted with DupliColor but top coated with urethane.
« Reply #2 on: November 30, 2007, 09:30:09 AM »
I have never used their "Enamel" on a plane, but I have used TONS of their lacquers.  Clear coat with dope or urethane.
They now offer quarts of lacquer in their *Paint Shop* line.  So far there are only 6 or 7 colors and clear in the quarts.  But, they do offer their filler primer in gallons!  Best primer I have used other than dope and zinc sterate.
Offline Rotten
« Reply #3 on: November 30, 2007, 11:22:34 AM »
Sorry to stray off topic. But MAN!!! that is one nice Airplane!!!!
Offline joe renfro
« Reply #4 on: November 30, 2007, 07:21:25 PM »
Bill..is the lacquer in the spray cans or is this something to be put on with a spray rig.....and when you mentioned urethane..again is this auto multi-part urethane or something like Red Devil or MiniWax in a rattle can.....I learned the hard way...that Miniwax spray can stuff will NOT stick to spray can lacquer by Rustloeum....And it looked so nice before the clear just started flaking off....Wasn't sure whether Randolph's Dope was fuelproof...Is all dope fuelproof or does it have to specifically say on the product?
Thanks...
« Reply #5 on: December 01, 2007, 10:19:36 AM »
Hi Joe,
Unless it says "Acrylic Enamel" on the Duplicolor can, it is acrylic lacquer.  There are large and small spray cans of Duplicolor, plus their new Paint Shop line which is a VOC compliant lacquer in quart cans..  The enamel is in black spray cans, IIRC.
Randolph's butyrate is as hot fuel proof as any other dope.  Nitrate is NOT hot fuel proof.
The urethane I referred to is automotive two part urethane.  But, I have sprayed Sig Lite Coat over Duplicolor many times.  I am not in the least bit familiar with Lustercoat and other hobby spray cans of paint.  Just never have had to use them, sorry.
Offline joe renfro
« Reply #6 on: December 01, 2007, 10:44:45 AM »
Ok..here is my gameplan...clearcoat the frame with Randolph's clear nitrate...and then use to put on covering..polyester..silkspan..whatever...couple coats of the same thinned clear and then finish with Buytrate dope which Aircraft Spruce sells much cheaper than any LHS I have found
or....finish with the DupliColor Lacquer spray cans for a bigger variety of color
But here is a question..back in the day..I used AeroGloss..Pactra..nitrate dope and it was fuelproof..wasn't it..nothing ever came off..or was it treated some special way?
So many questions..so many products
« Reply #7 on: December 01, 2007, 11:09:35 AM »
Joe, you can use th eDuplicolor lacquers for your colors with out problem.  What you are discribeing is the process I use.  Randolph's nontautening tinted nitrate up through covering. Then tautening butyrate (Sig or Randolph) on the open bays to shrink it.  Duplicolor filler/primer (usually), a blocking coat of anything BUT nitrate (!), in other words, Sig, Brodak, Randolph, or Duplicolor.  This is *almost* white, but it is gray.
Then for colors I user what ever I have around.  Sig, Randolph, Brodak, Duplicolor, in combinations.
Finally, clear with Dupont ChromaClear, Napa Econo Clear, or Sig Lite Coat.
Offline Terry Bolin
  • Havin' the time of our lives!
« Reply #8 on: December 16, 2007, 07:56:11 AM »
On the clears mentioned, you still have to mix a percentage of hardener right? what is the smallest quantity they sell of those brand clears, I hate to have a gallon around. This may be a silly question but, has any one tried the "Lusterkote" over their colors and had any problems?
Terry B.
« Reply #9 on: December 16, 2007, 12:21:08 PM »
Terry B.
HI Terry,
The smallest amount I have found is quarts.  And yes, there is a hardener to go with them.
Never tried Lustercoat on anything!  n~
I bought the NAPA Econocoat in the gallon size for around $50.  The shelf life is longer than I will be alive......... LL~
Offline don Burke
« Reply #10 on: December 17, 2007, 05:51:33 AM »
I've used LUSTERKOTE clear, and the colors, on my racers.  Holds up really well for that purpose, probably not a "front row" type finish however.  The colors without a clear coat will stain from the synthetic oil in the 10/10 mix we use.
The sprayed polyurethane is something I've never used, but probably the best.  I do understand that some of those automotive paints are highly toxic and require use of external breathing aparatus when spraying.  IMRON comes to mind.
don Burke AMA 843
Menifee, CA
« Reply #11 on: December 17, 2007, 07:27:21 AM »
Hi Don,
I haven't heard of anyone using Imron lately, like in th epast 10-15 years.  That stuff is way too toxic for our use.  I do believe Winfred had to take a Hospital tour for a while due to Imron.
The catalized polyurethanes are not quite as bad, but the chemicals can leach through you skin.  So, if you are going to have any prolonged exposure, a body suit, beyond a respirator, is necessary.
Offline joe renfro
« Reply #12 on: December 20, 2007, 02:34:34 AM »
PPG makes a 3 part paint called Deltron..I think it is very similar to Imron which is made by Dupont. Imron is much more costly, but I think the Deltron is in the same class..just doesn't have the name recognition....I painted a sailboat with the Deltron several years ago....It still looks very sharp..and thats sitting in the sun at a marina 24/7...Breathing apparatus strongly recommended!
