  • August 02, 2025, 05:46:31 AM
Author Topic: Dope shrinking on wing-fuse fillets  (Read 1436 times)
Offline Tom Weedon
« on: April 12, 2007, 06:13:36 PM »
I'm at my wits end! All I can do is scream!  I have been working on the wing to fuse fillets on a Smoothie for the last two (2) months and I'm loosing the battle. I applied a nice epoxy filler material to make a 1/2 inch radius on the wing root fillet about two months ago. I have been spray panting the airplane with a thinned covering of white AeroGloss dope. PROBLEM!!!!  Everytime the dope dries, it shrinks and pulls away from the fillet. I have sanded and primed the fillet a dozen or more times. I have sanded down to the bare filler and started again at least 3 times. The dopes still shrinks and pulls away from the fillet. I added a drop a caster oil per ounce of dope to keep the dope from shrinking so much. No improvement! Every time the dope drys it shrinks away from the fillet. I slice the fillet with a knife, fill with thin CA and sand and paint again. Same results!
Does anyone out there have a suggestion?  HELP; PLEASE!    n~
Tom W.
Tom Weedon, AMA 2537
Re: Dope shrinking on wing-fuse fillets
« Reply #1 on: April 12, 2007, 06:23:14 PM »
How much thinner are you adding? Spraying or brushing? How heavy are you spraying the dope? What exact material did you use to make the fillets? What are the conditions where you are applying paint? (hot, cold, humid) How much retarder have you used?
All questions that bear on the problem.
Offline Tom Weedon
« Reply #2 on: April 12, 2007, 06:46:59 PM »
Randy,
I thin about 50-50. The Aerogloss is aready thin compared to SIG dope. I used Super Fil (made by Poly Fiber, in Texas) two part epoxy to make the fillet. Super Fil is very lite and easy to work with. I've used it on other planes. The temperature in my basement is between 65 and 70 and the humidity is about 60%. I haven't used retarder. I used the caster oil to add elasticity to the dope so that it wouldn't shrink so much. I don't know what else I can do. I would have had this plane finished a long time ago if it wasn't for this damn fillet problem.  ???
Offline Bill Smith
« Reply #3 on: April 15, 2007, 07:19:46 PM »
Dope the fillets first with straight dope.  I have also used CA on the fillets first to keep the thinner from soaking into the fillets too much. If too much thinner get into the fillets the surface dries first and shrinks away from the fillets before it dries enough to bond to the fillet.
At least thats the way it seems to me.
I have also found that Brodak dope dries differently and is less likely to pull up (but it will wash off with high nitro).
Offline dennis lipsett
« Reply #4 on: April 15, 2007, 08:16:16 PM »
Bill smith os right about putting a barrier down before using dope. I usually use Sigment or Ambroid or Duco cement and a lot of times I never dope the fillet but go directly to the primer and use that to fill and finish the fillet.
Dennis
