  • June 19, 2025, 11:03:38 PM
Author Topic: blank  (Read 1311 times)
blank
« on: May 30, 2019, 04:43:38 PM »
blank
« Last Edit: September 07, 2021, 12:06:49 PM by Motorman »
Re: Which formers are plywood
« Reply #1 on: May 30, 2019, 08:40:24 PM »
I'm building a Tundergazer type fuselage (not a take apart) and I don't remember what the former by the flap horn is made of 1/8" balsa or 1/8" lite ply. F1,2,3 are ply because they hold the motor and battery but what about the one right behind the wing?
  I can see no good reason for that to be plywood unless you are making it a "from the bottom" take-apart and need it to hold the screws. My former in that position is built up from 1/16 x 3/8 balsa strip.
« Reply #2 on: May 31, 2019, 10:33:02 AM »
I use balsa laminated crossgrain pieces.
