  • June 14, 2025, 07:44:40 PM
Author Topic: Quckie V  (Read 6215 times)
Online RC Storick
Quckie V
« on: February 08, 2014, 02:32:18 PM »
Today I look around my shop for something to do. So I cleaned the ink pens and then found nothing. So I dug through my scraps and looked at the good wood I had. I got the idea to build a quickie Viper out of the stuff I have on hand. I have 4 foam cores I choose the lightest ones and I cut the length to the size I want. Now I am laying out the spars and finding the wood to use. I should have a kit cut by days end.
I am going to see if I can spit one out a little faster. No guarantees but I get to test some other configurations. I might just like them. Snow is on the ground so I might as well do something.
I will post pictures later.
Re: Quckie V
« Reply #1 on: February 08, 2014, 03:06:08 PM »
Going with a foam wing?  I hear it is possible to build one about as light as all wood, but have not done so, myself, so far.  Gonna really be watching this!
BIG Bear
Offline Serge_Krauss
Re: Quckie V
« Reply #2 on: February 08, 2014, 07:46:37 PM »
Onward and upward! Let's see...
I finished a horizontal tail, and you built a Schneider Cup stunter.
I contoured a profile fuselage and fit the wing and tail to it, while you built a Viper.
'wonder what I'll get done while you do this one.
I think I have about 3-4 of your work days left to finish the plane. 'may see air time by May. I'm delighted to watch your building posts. But wait! THAT'S why I'm so slow. Yeah, that's it. Ha!
SK
Re: Quckie V
« Reply #3 on: February 08, 2014, 09:05:12 PM »
 As fast as you build Sparky I figure you might save yourself about a day by starting with a foam core.  Will it be a fully sheeted wing then or...?
Online RC Storick
Re: Quckie V
« Reply #4 on: February 08, 2014, 09:08:54 PM »
fully sheeted.
Re: Quckie V
« Reply #5 on: February 09, 2014, 08:28:22 AM »
Hey if still using electric power you can forget the  doping of the plane.
Re: Quckie V
« Reply #6 on: February 09, 2014, 08:06:44 PM »
 True, but a dope finish still has lots of advantages. A well done dope finish is still very light, it's easy to work with, and it's very tolerant to any repairs or touch-up work. Also, many folks here already have years of experience using it, so a guy might as well just stick with it.
Re: Quckie V
« Reply #7 on: February 12, 2014, 07:51:30 PM »
 Moving along Sparky?
Online RC Storick
Re: Quckie V
« Reply #8 on: February 14, 2014, 04:03:51 PM »
Fuse is done and Stab and elevators are finished with 3 coats of clear. I am waiting on wing sheeting wood. And it will go together. Maybe by next week the wing will be done and it will be ready to assemble.
Offline MarcusCordeiro
Re: Quckie V
« Reply #9 on: February 16, 2014, 02:35:15 AM »
Pics? Please.
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
Online RC Storick
Re: Quckie V
« Reply #10 on: February 16, 2014, 12:41:08 PM »
Progress so far. After I got the wood for the sheeting of the wing I did so.
  • Wing sheeted
  • Fuse built
  • stab and ele finished and covered
  • Wing tips roughed
  • all horns and hinges made
8 Days work
Offline Jason Greer
Re: Quckie V
« Reply #11 on: February 16, 2014, 03:28:00 PM »
You are a machine Robert. And your work is flawless! I've worked three straight nights and all I have to show for it is a set of wing ribs.
« Last Edit: February 16, 2014, 07:24:22 PM by Jason Greer »
El Dorado, AR
AMA 518858
Re: Quckie V
« Reply #12 on: February 16, 2014, 07:22:40 PM »
 Is that a foam turtledeck?
Online RC Storick
Re: Quckie V
« Reply #13 on: February 16, 2014, 07:31:22 PM »
Re: Quckie V
« Reply #14 on: February 16, 2014, 09:52:32 PM »
Online RC Storick
Re: Quckie V
« Reply #15 on: February 16, 2014, 09:57:04 PM »
yes its the buck for molded deck
Re: Quckie V
« Reply #16 on: February 16, 2014, 10:15:00 PM »
 I just noticed another thing, the cowl is going to be on the bottom this time? It looks suspiciously like an IC setup... S?P ;D
Online RC Storick
Re: Quckie V
« Reply #17 on: February 16, 2014, 10:33:25 PM »
Looks like you'll have to wait.
Re: Quckie V
« Reply #18 on: February 16, 2014, 10:47:49 PM »
Online RC Storick
Quckie V Mocup (pic)
« Reply #19 on: February 19, 2014, 11:29:22 AM »
Here is where I am at. 11 days work
Offline Allan Perret
  • Proverbs
Re: Quckie V
« Reply #20 on: February 19, 2014, 07:48:16 PM »
Can you elaborate a little on your process for sheeting the foam core wings.
Also in the "Foam vs Built-Up" thread you mentioned not using a spar in the foam cores.  Is that a common practice ?
« Last Edit: February 20, 2014, 06:27:00 AM by Allan Perret »
Allan Perret
AMA 302406
Slidell, Louisiana
Re: Quckie V
« Reply #21 on: February 19, 2014, 11:13:37 PM »
 ...or a lot. ;D
Re: Quckie V
« Reply #22 on: February 20, 2014, 06:20:18 AM »
Is that Canbon veil at the wing joint??
Marcus
Aces High!
Online RC Storick
Re: Quckie V
« Reply #23 on: February 20, 2014, 07:41:19 AM »
There are quite a few guys more qualified to give instructions on sheeting that I. I just followed Bob Hunts directions on sheeting. But a quick run down is. Join sheeting, spray with hair spray ,apply Z-poxy, put wings in cradles and weight down. Let dry over night. Join in center with slow set epoxy. Apply 2 layers of CF tissue in center then silkspan.
Online RC Storick
Re: Quckie V
« Reply #24 on: February 20, 2014, 03:54:50 PM »
Today I did the knickknack stuff. Plywood bellcrank mounts top and bottom. Mounted the stab and finished the pushrods. Got the motor set and mount glued in. 1 coat of clear on the wings and stab. Its moving right along and should be all together by Monday. I need batteries for the camera so it will be a day or two for pictures.
Online RC Storick
Re: Quckie V
« Reply #25 on: February 21, 2014, 12:16:40 PM »
No batteries yet but I am almost done with the wood work. All that's left is turtle deck, canopy and rudder. I am quite pleased with the way my FREE plane turned out. Well nothing is free but this is built from my scraps and I have enough scraps for one more.
You never know I will fly all my planes and this could be the best. If according to the masses that a heavier plane fly's better which I doubt but this will really tell. I am thinking it will be around 5 ounces heavier at 60 ounces when finished.
Re: Quckie V
« Reply #26 on: February 21, 2014, 03:04:22 PM »
  As mentioned in the other thread, all of our foam-wing planes came out stiffer and much more consistent than the equivalent built-up that was otherwise identical. It's hard enough to trim these guys, it's even harder when it changes from hour to hour.
Online RC Storick
Quckie V The finish begins
« Reply #27 on: February 24, 2014, 08:29:13 AM »
Its all together and ready to start finishing. Here are some pics.
16 days to here
Re: Quckie V
« Reply #28 on: February 24, 2014, 11:00:13 PM »
 Lookin' good. y1 What's the wingspan on this one?
Online RC Storick
Re: Quckie V
« Reply #29 on: February 24, 2014, 11:02:12 PM »
59 inches and 660 squares
