https://stunthanger.com/smf/open-forum/how-do-you-mount-belcrank-in-a-foam-wing-core/msg388732/#msg388732Reply #7 answers all your questions, plus the ones you forgot to ask.
It is steel used for car caroseries, so standard, not hardened, not plated, but high tensile, not soft.
Okay, forgive the obtuse question. If the wing and fuselage are built separately, you have to cut a slot in the fuselage to clear the top and bottom of te pins when you slide the wing in place. Looking at the photos of Bob's plane, I don't see how he did that. The fuselage and ply doubler look intact. How did he do it?Mark
"Not hardened but high tensile" sounds like a bit of an oxymoron to me -- but car body steel is weird stuff these days. It comes out of the mill soft, and age hardens. The idea is that it's soft for the punching process, and then hardens itself by the time the car gets out of the factory. That way you can have a strong, lightweight car body without having to even think of heat-treating sheet metal (which would be nuts).
