  • July 11, 2025, 12:45:25 AM
Author Topic: Wing mounting / covering ?  (Read 1439 times)
Offline Rob Killick
« on: February 01, 2007, 07:00:36 PM »
Hi ,
I was wondering what the best way to assemble the main components of the aircraft ... ?
Should I install the uncovered wings to the fuse , then cover the major assembly ( I'm thinking a wood to wood bond would be stronger ) ?
I'malso thinking epoxy is the way to go for the wing / fuse bond ?
One last question ...
Is it proper to cover the horizontal stab and vertical stab with silkspan ?
Thanks for letting me bend your ear(s) :)
Rob Killick , MAAC 33300
Re: Wing mounting / covering ?
« Reply #1 on: February 01, 2007, 10:13:52 PM »
Hi ,
Hi Rob,
You can do things either way.  Some like to completely finish, up through covering, all the major components then assemble them.
Others cover everything after the parts are assembled.
If you are using the traditional dope/silkspan process, it is no problem.  Do use epoxy on the wing/fuselage joint.
If you are using any of the iron on films, you will need to remove the film where you are going to glue the joints.
Precovering everything before assembly makes the covering job easier, but I tend to poke holes in the wing if I do it that way!  LOL!!  So I cover everything but the wing usually, then cover it after gluing everything up.
Bill <><
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #2 on: February 02, 2007, 08:27:11 AM »
One warning, if you cover a wing with Polyspan before you put it in the fuselage, put several coats of clear on it before you start handling it. Long story but lesson learned  ;)
Offline rob biddle
« Reply #3 on: February 02, 2007, 02:11:18 PM »
  Hi Rob,
  Just personal preference but I like to cover the wing after it's mounted to the fuselage, mainly because nearly always I have to tweak a few things to get everything mounted properly and don't want to risk puncturing the silkspan whilst handling the wing.
 Cheers, Rob.
Robert Biddle
Offline Mike Greb
« Reply #4 on: February 04, 2007, 05:52:33 AM »
On most of my models I monokote the wing and maybe the stab. and leave the gluing areas uncovered.  When I instatll the fillets I overlap them over the film covering, that keeps the edges down and most of the oil out.
