  • June 17, 2025, 07:53:01 AM
Author Topic: Tom Morris Handle Shaping  (Read 3778 times)
Offline Phil Goldberg
  • Just completed this PDK Buster 45
« on: June 26, 2017, 11:56:36 AM »
I am assuming that the Tom Morris Handle Shaping is done on the bolsters that fit in the palm.  To do so I might put some powder on my hand, grip the handle and therefore find the spots that can be shaped for a custom fit.  Am I on track?   Phil
Offline Chris Belcher
Re: Tom Morris Handle Shaping
« Reply #1 on: June 30, 2017, 10:00:52 AM »
I have 3 of these and the last one I just basically removed the hunks of wood on both sides...never had that much luck "customizing" to the shape of my hand...but i like a skinny feelling handle. I like to feel the pull in my index and pinky fingers.
« Reply #2 on: June 30, 2017, 02:12:36 PM »
With both the Brodak & Morris handles I glue balsa blocks to the wood handles, then sanded the balsa to fit me.
« Reply #3 on: June 30, 2017, 03:50:59 PM »
The Morris handles he's talking about already have 2 huge chunks of wood on the sides that you are supposed to custom shape to your hand. I guess the powder thing would work if you gripped it and then drew on the lines ...I just always ended up carving/sanding 95% of the wood away. I recently purchased a KAZ hardpoint and some hello kitty clips and have been VERY pleased...once I narrowed the spacing. These are very nice, well made and fully adjustable..they will adjust your wallet a bit as well:)
« Reply #4 on: July 01, 2017, 11:21:07 PM »
Haven't used a TM handle in quite awhile, but the first thing I had to do was remove most of the finger scallops, then a lot of the side pieces, and then replaced the hex nuts with elastic lock nuts.  D>K Steve
« Reply #5 on: July 02, 2017, 06:16:51 PM »
   My suggestion would be to make it as close to a Hot Rock as possible in the basic shape, and adjust it only in the area to ensure that your fingers touch the forward projections. In particular, don't put any tilt or funny angles in it, or thumbrests, or anything like that.
Offline dave siegler
  • sport flier
    • Circlemasters Flying club
« Reply #6 on: July 03, 2017, 06:23:19 AM »
How about putting on a disposal rubber glove and smearing the whole thing with Bondo grab the Bondo to make a custom impression
Dave Siegler
NE9N extra class
AMA 720731
Offline Brent Williams
« Reply #7 on: July 03, 2017, 03:50:23 PM »
IMHO, I'd nix that bondo idea on your Morris handle.  Don't add unnecessary weight to the handle for some dubious ergonomic gain.
You've gotta hang on to the handle (and the tug of the plane) for 6'ish minutes and then complete some challenging maneuvers towards the end of the pattern.  Why add fatigue to the mix.  Try and keep the overall weight to a minimum.
« Reply #8 on: July 04, 2017, 09:05:49 AM »
Sounds like some one needs some gym work.  I have so many handles to fly with and I think the heaviest is one I bought from Dick Byron at VSC to tame down my Dragon.  The lightest is the Expo handle from Larry Renger.  But, when I'm flying I never notice the weight difference let alone think about it as the planes have decent pull/tension on the lines.
I guess if I was standing there holding my arm out straight with the handle in my grip it might get heavy.   But, then again the arm gets heavy with out holding any thing.   Try it some time in your living room when no one is around.    S?P H^^
  • sport flier
« Reply #9 on: July 04, 2017, 05:15:54 PM »
It's a little Bondo not a lead casting.   Less than the size of a golf ball
My bono handle is still lighter than some off the shelf ones.  That handle is impossible to pickup upside down
Dave Siegler
NE9N extra class
AMA 720731
« Reply #10 on: July 05, 2017, 07:34:46 PM »
Anything that doesn't feel good to your paw needs to go. Balsa side chunks would make it easier, but the pine (?) isn't too bad if you attack it with the correct tools...coarse wood rasp, very coarse sandpaper, etc. There's way more wood there than you need, except perhaps where some may need to be added (per Mr. Buck's instructions) to make the handle fit snugly on the index and pinky fingers.
I hope Brett wasn't making fun of the thumb locator on my Chris/Alan/Arkady CF handle, 'cause it's peachy. Helps keep my thumb from drifting upwards. All the other fingers are a snug fit, so why not the thumb? H^^ Steve
« Reply #11 on: August 07, 2017, 11:30:38 AM »
I'm not sure what the plastic was, but Art Adamisin was making personal handles that way back in the 60's.
« Reply #12 on: August 07, 2017, 11:05:16 PM »
Hmmm.  If someone believes he/she needs a handle a half oz lighter than his/her existing handle in order to prevent pilot fatigue prior to the tough maneuvers I think a better first step would be to get more exercise or, if exercise tires one even more than flying with the "heavy" old handle, decrease the lap times by a tenth of a second and allow the airplane's increased tension to do the heavy lifting.
Ted
« Reply #13 on: August 08, 2017, 10:24:30 AM »
Thanks Ted.  There are only 2 handles I could tell when I was flying them or picking them up, the old Fox  handle and the J-Roberts throttle control handle.  But once plane was air born I never noticed the weight of the handle.   Especially a Sterling Gaurdian with McCoy Redhead 60 on high speed. H^^
