  • June 17, 2025, 03:07:50 AM
Author Topic: Stiletto profile  (Read 11516 times)
Offline MarcusCordeiro
Stiletto profile
« on: July 26, 2014, 09:29:59 PM »
I had to decide my next build. So, here it is....
Stiletto profile by Walter Umland.
Really cool kit....
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
Offline Dane Martin
  • heli pilot BHOR
Re: Stiletto profile
« Reply #1 on: July 26, 2014, 11:42:24 PM »
outstanding Marcus! that's gonna be great!
« Reply #2 on: July 27, 2014, 07:29:16 AM »
An Umland kit will spoil you.  Don't ask me how I know.  Will have to go look at his site again as I don't remember this one.
« Reply #3 on: July 27, 2014, 04:28:37 PM »
You're right John...LOL...
Ty, undecided right now, but i've got a T&L ST46, one brand new LA 46, ST 51 and thought of a Enya 50SS...
All good choices.... I'm leaning towards the Enya.... A couple more weeks and I'll make my mind...
Such a great kit....
Marcus
Aces High!
« Reply #4 on: August 13, 2014, 06:44:36 PM »
The weather has been too cold and rainy to paint, so I advanced a little more on this build.
Sheerwebbing of the back of the TE sheeting and the spars done.
Now i'll glue the TE cap and work on the wingtips.
Complete control system by Tom Morris on the way...
This Bird looks better and better!!! ;D 8)
Marcus
Aces High!
« Reply #5 on: August 26, 2014, 07:25:48 PM »
Life has been a little tough, and I haven't had time to work on my ships these days...
anyway, the control system has arrived... Thanks Tom Morris!!!
Marcus
Aces High!
« Reply #6 on: August 27, 2014, 05:46:15 AM »
Marcus
The Mark!
Nice clean set-up. Not sure if the "double" horns are really necessary? Ya think?
I've used Tom Morris' hardware on all my models except the Flite Streak. He does really nice detailed work. To your specks also.
Are those leadouts solid wire?
Charles
« Reply #7 on: August 27, 2014, 02:47:39 PM »
Marcus,
Did you finish the Magnum?
« Reply #8 on: September 01, 2014, 08:11:23 PM »
No Charles, braided..
Randy, as soon as i finish paiting the Thundergzer, i'll paint the Magnum. It still needs some sanding.
This year has been a tough one ad my builds are way behind schedule....
Tomorrow is another day...
Marcus
Aces High!
« Reply #9 on: September 02, 2014, 06:46:42 AM »
Marcus,
Will you use iron on plastic material on that model?
What will you cover it with?
« Reply #10 on: September 02, 2014, 01:28:23 PM »
I've been thinking of going with polyspan, never used the thing, it seems good....
Marcus
Aces High!
Offline Mike Lauerman
« Reply #11 on: September 05, 2014, 01:00:32 PM »
Hi, Marcus. Beautiful work on that wing!
A question that I've tried to 'reason out': On the plan pic with the Morris system sitting atop the flap connection, do the flaps have (brass?) tubing glued into their leading edges, and the Morris horn legs just slide in? Or are they glued/epoxied to those pieces of tubing?
« Reply #12 on: September 05, 2014, 08:55:00 PM »
Thanks!
What you see is the Lucky box option that the plan shows. there's no tubing in the flap.
I've installed the bellcrank,by the way...
I'll post more pics when there's more...
Marcus
Aces High!
« Reply #13 on: September 08, 2014, 04:34:56 PM »
Bellcrank... Thanks Tom Morris!
Marcus
Aces High!
« Reply #14 on: December 18, 2014, 05:28:02 PM »
So, back at it...
Marcus
Aces High!
« Reply #15 on: December 19, 2014, 08:38:10 AM »
Yes, life does get in the way at times.   I see you used the silicone tubing Tom puts in his bell crank sets.  I discard the stuff and put in ply spacers to keep the bell crank centered.  Also I leave enough rod, top and bottom so I can cut grooves for epoxy and ply to latch onto.  I lost my Sheeks Spitfire because the rod on  the bell crank worked it way out of the mounting.   The eyelets were J-B Welded and I guess I didn't clean the wire good enough.   Now use the wheel collars with a notch for the set screws.  This was one of the early bell cranks sets.  The build is looking  great.
