  • July 14, 2025, 03:36:53 PM
Author Topic: Dave Brown covering  (Read 2156 times)
Dave Brown covering
« on: December 18, 2006, 03:53:40 PM »
Hi Y'all,
Dave Brown advertises a nylon based covering that is claimed to fill with two to three coats of dope.  Has anyone out there in stunt land ever used it and what didyathink?
Will
Offline Jim Oliver
Re: Dave Brown covering
« Reply #1 on: December 18, 2006, 07:40:23 PM »
If the product is Dave's Skyloft, it is very strong but very "un-light".  I used it on a 60 size RC model years ago and  I remember it well. ::)
Jim
Jim Oliver
AMA 18475
« Reply #2 on: December 20, 2006, 09:21:53 AM »
Thanks Jim,
The "unlight" part was part of my concern, so I guess I'll stick to my silkspan after all.  Everyone have a blessed Christmas out there!
Will :##
« Reply #3 on: December 20, 2006, 09:29:12 AM »
Is this stuff similar to the SIG Mfg. Coverall fabric covering?  DOC Holliday
« Reply #4 on: December 20, 2006, 11:31:10 PM »
Not at all. "Skyloft" is a nylon version of silkspan (i.e., mat), while Koverall is woven polyester fabric. Have Mrs. Doc explain the difference. The great F1C innovator (flappers and folders), Bill Gieskieng, used Skyloft over balsa sheet areas, applied with "Deft", a woodworker's varnish of some sort (I'll have to check Home Depot, someday). I'd bet he'd use CF mat, these days. I'm wondering if he'd use Deft, or something else, tho.  :! Steve
« Reply #5 on: December 21, 2006, 12:25:04 AM »
FWIW Deft is actually a cabinet laquer. Most that is available is a brushing laquer but it contains some catalyzing agent that actually causes some mild polymerization of the coating which makes it more durable.
« Reply #6 on: December 21, 2006, 10:56:31 PM »
Thanks for that info, Mark. It sounds like it might be useful stuff for applying FG or CF mat, then. Tho the water-based Minwax PolyAcrylic still seems like maybe a better choice, at least for some of us.  n~ Steve
« Reply #7 on: December 22, 2006, 08:56:52 AM »
Steve,
as you know, bieng a pro painter, I have to caution all about the mixing of products and chemicals. Not just to beware of the toxicity, though that is definetly a concern. Please oh Please experiment before you put anything on your labor of love. the use of any product over a different product is most always a recipe for disaster. Yes I know people do it and get away with it. I have had enough issues over the years staying within the same product family, the thought of one persons product over anothers makes the hair stand up on the back of my neck. That being said, give it a shot, all you got to loose is time and money. just remember for every time it works, its one shot closer to the time it will screw up . lol,,
besides if it doesnt work, you can use the left overs to refinish the furniture!
« Reply #8 on: December 22, 2006, 08:08:35 PM »
Mark...absolutely, tests would be done. That's half the fun. HB~>  LL~ ROFLMAO, Steve
Offline Paul Allen
« Reply #9 on: December 23, 2006, 12:31:39 AM »
Tried Dave Brown Skyloft a few years ago,went
on well but had a number of pin holes in after doping,
had to cover over it with lightweight silkspan.
Have been using Thermal Span from a company
in the U.S.A  trading as Harris Design,they had ads
in Stunt News a few years ago,similar to Polyspan
but stronger, needs adhesive applied to the frame
then ironed on similar to plastic film.
