  • June 19, 2025, 02:44:50 PM
Author Topic: ALERT! DuBro Ball Links  (Read 1196 times)
« on: May 03, 2013, 12:27:37 PM »
The DuBro Heavy Duty 4-40 ball links are used by many for our controls.  I recently bought a package, but the ball  joint was very stiff.  No amount of exercising, lapping, or oiling would make it work smoothly.
I then bought another package, and they all worked very well.
We work hard to make our control systems with minimum friction.  Ball links, when they are good, add very little friction overall.  If you get one that doesn't work smoothly, I guess it must be discarded in favor of another one.
It looks like a manufacturing problem where all products are not quite the same.
Re: ALERT! DuBro Ball Links
« Reply #1 on: May 03, 2013, 01:15:32 PM »
Floyd,
I agree, I have a discard bin where they tight ones go to play with themselves,,
now the helicopter guys have some sort of "ream" tool they use to adjust the tension by cleaning up the socket,, I dont think they use the same parts we do,, theirs come apart,,
« Reply #2 on: May 03, 2013, 07:00:05 PM »
I use the ones from Tom Morris. They seem to work very well. The only time I used the Dubro units was on the Cobra I built. They got tighter over time.
