  • July 11, 2025, 04:20:02 PM
Author Topic: cutting a slot in a profile fuse  (Read 5606 times)
Offline Steve Thornton
« on: January 29, 2012, 12:11:41 AM »
I am thinking about using "tie wraps" to mount a plastic tank on my Fancher Twister.  I have seen this technique and it really looks cleaner and a little more permanent than rubber bands.  My real problem is how to cut a thin slot in the fuse that the tie wrap will go through.  If I put the wrap around the whole fuse, it tends to crush the curved edge of the balsa tripler.  Anyone have any experience with tie wraps and cutting thin slots?
Thanks for any help.
Steve Thornton
"Most of us won't make it out of this world alive."
Steve Thornton
Offline Dick Pacini
Re: cutting a slot in a profile fuse
« Reply #1 on: January 29, 2012, 06:35:01 AM »
The tie-wraps you are probably going to use do not need to be very wide.  Why cut slots when a simple drilled hole will do?  I suppose if you are dead set on slots, then a Dremel tool with a small router bit could be used.  It would no doubt be a freehand operation as successful as your steady hand.
AMA 62221
Offline Steven Kientz
« Reply #2 on: January 29, 2012, 07:32:43 AM »
  Dremel makes a router attachment that fits around the bit. I have used it to "carve" some pretty intricate designs in pine. Should work on your slots.
Steve Kientz
AMA 855912
larry borden
« Reply #3 on: January 29, 2012, 09:21:38 AM »
I use the tie wrap method and simply drill holes for the wrap to go thru.
Offline PatRobinson
« Reply #4 on: January 29, 2012, 10:16:46 AM »
Hi guys,
If you want a narrow slot that is cut through 1/8th ply doublers and 1/2" balsa. A bit or blade that can cut deep enough will cut a slot that may be wider than you want. The easiest solution is to drill a hole big enough for the tie and then use an epoxy micro balloon mixture to fill part of the hole to give a clean slot look.
        Pat Robinson
Offline Allan Perret
  • Proverbs
« Reply #5 on: January 29, 2012, 11:28:20 AM »
Drill 2 small holes (1/16" bit) about 3/8" apart,  cut out material between holes with hobby knife.
Allan Perret
AMA 302406
Slidell, Louisiana
Online Howard Rush
« Reply #6 on: January 29, 2012, 01:51:40 PM »
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #7 on: January 29, 2012, 05:39:22 PM »
Been mounting my tanks this way for quite some time. I cheat and use my mill before I install the wing. Found and ordered a couple extra long small end mills off the net. They are long enough to go all the way through both doublers and 1/2 inch balsa. Have to use a low feed speed but they turn out looking, well like they were machined.
Before I bought the end mils I just drilled two small holes next to each other and used jewlers files to clean out the material between the holes.
Online Howard Rush
« Reply #8 on: January 29, 2012, 07:30:54 PM »
Using a mill should be a violation of the BOM.
« Reply #9 on: January 29, 2012, 07:33:04 PM »
See Howard, now that's just mean. Does that mean that using a post cure oven is a violation?
Online Howard Rush
« Reply #10 on: January 29, 2012, 08:36:53 PM »
It's borderline.  An autoclave is a violation.  So is clearcoat that doesn't blush.
« Reply #11 on: January 29, 2012, 11:49:56 PM »
How about this?  http://durafix.com/blades/copingsaw/
Howard have you used a saw like this?  I have seen them but don't know how much practice I would need before I tried it on a plane.  I am leaning toward smaller wraps through drilled holes.
Steve Thornton
« Reply #12 on: January 30, 2012, 11:45:16 AM »
Man, Howard, your shop is one big BOM violation. Sheesh!
Online Howard Rush
« Reply #13 on: January 30, 2012, 06:13:12 PM »
No.  I saw the question, admired your wanting the slots to be just right, figured that something like this saw ought to exist, then found it with Google.
Offline Bob Johnson
  • Lone Eagle Stunt Flyers -Have stooge. will travel.
« Reply #14 on: January 31, 2012, 08:07:46 AM »
No slots or holes needed. I use plastic phone wire clips/staples. Replace the nail with a screw (I also sand down the clip for a better/closer fit) and mount a little above and below the tank. This allows for height adjustment (balsa shim if needed) slide your zip ties through the clips (added pad is nice) and tighten down. if you want more or better photos let me know I can do a step by step if you want. Cheers,
Bob
Offline Ed Keller
« Reply #15 on: January 31, 2012, 10:47:53 AM »
Where do we get the stuff? (clips, etc)  Ed
« Reply #16 on: January 31, 2012, 01:16:47 PM »
Great idea Bob!  Are these the wire guides that hold phone wires/cables "neatly out of sight?"  Those I have seen have a flat portion (for the screw/nail to go through) attached to a circular piece that actually holds the cable.  I also am experimenting with with cutting the ratchet end of a wider tie wrap, and just screwing each end into the fuselage.  I'll let you know how it goes.
Thanks Steve
Steve Thornton
Offline Dick Pacini
« Reply #17 on: January 31, 2012, 02:50:44 PM »
AMA 62221
Offline Bob Johnson
« Reply #18 on: February 01, 2012, 09:33:08 AM »
OK. This is how I do it. (Photo 1) The wire clips in question. Sadly I tossed the packaging so I can’t tell you the brand, I think they’re G&B. The nail is removed and replaced by a ½ or 3/4 in. DuBro #4 cap head screw or similar. The clip can be ground down thinner by about 1/6 in. if desired. Note- Abe for scale.
(Photo 2) The clips are screwed/mounted to the fuse. Space can be left for tank height adjustment, and a balsa strip used as a shim between the clips and tank as needed.
(Photo 3) The zip ties are slipped through the slots the tank and foam pad (if desired) set on the ties between the clips.
(Photo 4) The zip ties are closed up. Note- keep the lock end near the apex of the wedge ( if that’s the type of tank your using) to afford a more snug fit. Also beware of over tightening, the clips can break form too much stress and/or fatigue.
(Photo 5) trim excess zip tie. Note- I like to set it up so the tie ends point down, I think it looks better and is more comfortable when starting. I should also mention I prefer the thinnest, longest ties I can find, you can also join two together if necessary. And they come in colors so you can coordinate with your paint job. Hope this helps.
Bob
« Reply #19 on: February 04, 2012, 10:46:39 AM »
Bob that's exactly the solution I've been looking for! Very tidy and functional.  HD and Lowe's have the cable keepers in a couple of different colors; black, brown, and white.
Steve Thornton
Offline Bill Adair
  • AMA 182626
« Reply #20 on: February 04, 2012, 12:39:51 PM »
I use "Low profile" tie wraps. The trimmed end than lays flat against wrap, and looks much neater.
Offline Geoff Goodworth
« Reply #21 on: February 04, 2012, 04:42:26 PM »
On seeing this, I was reminded of a completely different cable tie mount that I have seen in the Oz equivalent to Radio Shack.
Aircraft Spruce sells them in large quantities http://www.aircraftspruce.com/catalog/elpages/cabletiemounts.php
Offline Bob Reeves
« Reply #22 on: February 05, 2012, 03:06:57 AM »
I think slots look much better than clips, hooks or any added hardware that isn't really needed. This is my OTS Ringmaster and one I did before I started doing them on my mill.
Grady Widener
« Reply #23 on: February 05, 2012, 11:40:12 PM »
This a top down view and I build them like this because it maintains a wet uniflow vent wet better than any other design I'm aware of. This is important because it keeps the engine from going rich at the wrong time per slosh slosh and the uniflow becomes unsubmerged. When the uniflow (naked silicone tube next to sintered bronze DurBo filter) finds itself in air and not fluid, the engine doesn't have to suck as hard as it did when the tank was full so it goes rich at just the wrong time....badness.
You must use a sintered bronze filter for this setup to work because the surface tension of the fuel won't allow any air to be sucked through the pickup which is the bronze thingy.
A 5/32 extender is soldered to the bronze filter to provide room to solder the 1/32 music wire loop which traps the naked silicone uniflow tube.
Looking straight at the cap which houses all the tubes finds the uniflow vent @ 9, the overflow @ 2 and the engine feed line @ 5.
Got to tweak the dickens out of the copper tubes that transition through the cap to make sure the clunk falls dead center when held vertical and that there are no binds in clunk action.....professional real estate management. The clunk must also be symmetrically located when the plane is held either upright or inverted.
The overflow is cut real short and a silicone extender is added because you can't get the thing together if you don't. Also helps to rotate the overflow @ 90° outboard when installing cap, then rotating back vertical once all together.
The big issue with this setup is you have to move the whole tank up or down to adjust for even speeds inside and out. No problem on a profile and mount @ 3/16 above engine centerline. Also, on a profile, don't build an adjustable tank saddle. Just use some Home Depot eyelets that you will have to cut open with a Dremel. Sanitary and slick with minimal additional outboard location....the main enemy of all profile set-ups. Sorry if it's not right out of the gate. Plug and redrill when you get home to achieve correct height. Additionally, it is wise to build an angled silicone foot for the tank to seat on with a slight outboard bias. Make sure the tank sits widest part is against the fuse to mitigate excessive centrifugal loading per engine thinks liquid going too far uphill once tank half empty and too lean run-away is the standard result. Use the blue and white tube of GE silicone (again available @ HD) and some wax paper. Rough up fuse side tank base, blob silicone and let rest a day or two on flat surface before separating from wax paper.
If you've got the room, this dude is a solid performer and make sure to pressure test capped off with syringe and coffee can full of water prior to installation.
If center clamp screw leaks, some professional grade black silicone seal will remedy and I like to use a washer under the screw as well.
Best,
Grady
Offline Dick Pacini
« Reply #24 on: February 06, 2012, 06:11:57 AM »
Bob, how does the inboard mounted tank work out?  Can you tell a difference in performance?
AMA 62221
Grady Widener
« Reply #25 on: February 06, 2012, 07:15:05 AM »
How does inboard work with a big fat 1/4 - 1/2 vibration dampening inboard balsa trippler or cheek that's always found on the best running profile jobs?
« Last Edit: February 06, 2012, 07:38:26 AM by Grady Widener »
Offline Bob Reeves
« Reply #26 on: February 06, 2012, 03:06:30 PM »
Works just fine, can't tell the difference.. Have 3 profiles with inboard tanks and they all run great. The only problem with the Ringmaster is the Fox, one of these days I'll get around to putting a stick in the bypass. Actually maybe not, it's really fun to hear the big gasp from spectators when it quits and comes back to life, this one is really burp city if I get off a little rich. And no it has nothing to do with the tank, it's a Fox...
Offline Bob Reeves
« Reply #27 on: February 06, 2012, 03:12:53 PM »
On the wrong computer to post a photo but guess you haven't seen my Shoestring. You make a channel for the wire tie, on my larger profiles the tank is on the engine side but still held on with wire ties through slots.
Offline Joseph Patterson
  • AMA member- Supporter
« Reply #28 on: February 07, 2012, 05:48:43 AM »
      A scroll saw will work if (2) small holes are drilled, then take scroll blade lose on one end put through one of the drilled holes and reinsert blade back in saw. All the ideas given here are great. Thanks.
      Doug
Tags: tie wrap
