Building Tips and technical articles. => Building techniques => Topic started by: TDM on January 18, 2018, 09:25:08 AM
Hey I am making custom control horns for REvolution and I heave a question. What type of material do you use for the wire that goes in the horn. I need an exact name for it. I know it is some kind of spring steel but not sure which one.
Grade A2 air hardening drill rod.
http://www.clstunt.com/htdocs/dc/dcboard.php?az=show_topic&forum=103&topic_id=331672&mesg_id=331672&listing_type=search
https://stunthanger.com/smf/open-forum/cadmium-free-silver-brazing-material-question/
I've been using 7018 gas welding rod for quite a few years. A2 is fine if plan on never have to adjust with a bend; It will break. 7018 has a yield of 70,000 PSI, I've never had one fail, even through a crash. FYI this is not my invention, I know of quite a few other people who fly and build much better than I and that is what they use.
Guise here is where I am heading. There is no brazing in this horn. In my horns I bend 90 degrees and cut to length and the wire job is done.
A2 got it.
I have had *no* issues with the A2 tool steel. I tried to bend a horn back an forth (as if I were tweaking it - a LOT) and my hands got tired long before it broke. Did the same test with music wire, and it broke after maybe 20-30 cycles (of +-30 degrees or more). I concluded from that that the tool steel, as used, was *much* tougher than music wire. My only concern is that it might be too easy to "tweak" because it is substantially softer.
Yes Brett, tool steel is much tougher that music wire. A2 when heat treated is extremely brittle. Get it red hot and hit it with air it will break then. One problem with 7018 is that it might be too forgiving. It is *real* easy to tweak, at times too easy. Sometimes a little bump will mess up my flaps. With some care I'm generally good for the season. Going to Muncie is a different story. Well, it is anyway! A2 is probably fine, I have always worried about a stress riser from the heat at the joint.
A2 got it.
You selling this ?
Alan not at this time. What you see is a prototype that will be modified. I want to have a bit more rigid connection between the two halves and i want to remove the legs since you can just tape one flaps in place hold the other one by hand and adjust by holding the flaps by hand. This system is made to work with ball links that attach with a 4-40 screw.
If you want one I can make you one.
And guise I have got some A2 drill rod.
Instead of having those long adjuster legs couldn’t you put the slot and screw on the same side as the pushrod?
I think this picture will clarify intent. This is the screw from where the adjustment comes. I did not put this picture and i think that created some confusion.
On one of the legs there is a radial slot in it. that radial slot allows the leg to be indexed radially and set in place with the screw.
For the real parts I plan to cut a flat on the wire in the position where the set screw will be.
Yes I understand. Can’t that slot and set screw be on the other side of the wire?
The adjustment set screw would be between the wire and the ball link on the control horn.
One half would have the control horn, with a threaded hole for the set screw. The other half would have a shorter ‘control horn’ with a slot for the set screw to tighten down on.
That would eliminate the long adjuster leg on the opposite side.
Already ahead of you. Yes that is a definite possibility. You can index and rotate features anywhere. FOr my purposes it is easier to reach the spot from a little hole under the wing and the set screws are easy to access from the wing cutout area so I rotate them forward.
OK i did a little searching.
A2 55000psi
1045 high strength carbon steel 77000psi
12L14 rotary shaft material 70000psi
The bend is identical for all 3 materials all 3 bend nicely without ant ill effects. For torsional stiffness which depending on the sheer strength length and cross section of the material i did not see much difference between the 12L14 or the 1045 carbon steel A2 seamed a little softer then the other two.
Hello Trian
I have made the Adjustable horn for the flaps in the past using that same idea not as beautiful as you have. There is a Thread on flap adjustment that made me improve mine to make it adjustable using a screw to be able to fine tune the flap after the first flight. Initially I used to use the horn I made to make absolutely sure that both flaps were parallel without giving any thought of fine tuning until I saw Paul Walker set up. I modified mine to be able to fine tune the plane`s flight but I haven`t been able to work on a new plane lately. I already have the wings built with the horn incorporated and can adjust from 0 degrees to plus or minus 5 degrees in small steps. here is the link to the thread so you can see the information and photos. Here is a pic.
https://stunthanger.com/smf/open-forum/flap-adjustment/
I'm still expecting somebody to make elevator and flap horns from CF...somehow. It would save a bunch of weight aft of the CG. Might want to change the basic "bent wire" plan that's been used since the late '40's or early '50's. D>K Steve
