  • June 13, 2025, 08:09:40 PM
Author Topic: covering with polyester dress lining  (Read 3127 times)
Offline Glen Wearden
« on: July 09, 2009, 05:29:31 PM »
Don't know if this is the right forum category for this, but here goes.  A few years ago, I read (can't remember if it was on the internet, or in a magazine) that polyester dress lining can be used for covering material.  From what I remember it is supposed to be quite strong, heat shrinkable, and fairly easy to fill and paint.  Has anyone here used this material; how did it work; what are the land mines, etc.?
Glen Wearden
Glen Wearden
Offline James C. Johnson
Re: covering with polyester dress lining
« Reply #1 on: July 09, 2009, 07:55:27 PM »
You can use it but I don't recommend it.. the weave is too loose and and fabric is a bit heavy.. when I was a kid I used drapery lining... later on I used parachute material ... that worked pretty well ....
Here is another modeler that might be doing what you want to do.
"Go to a fabric store and ask to see polyester dress lining. This is about the same as Sig's koverite and F&M's poly-fabric. Much cheaper! Heat shrinks and takes various finishes, dope, poly-tone, etc. Also, much cheaper than silk and comes in any length you want. Am using it to cover a Cessna UC-78 Bamboo Bomber. Attaches to the framework with dope or poly-tack or Sig stik-it. Cost was about $3.65 per yard for 50" wide. Regards."
Here is the link to the whole thread on RC Universe.
http://www.rcuniverse.com/forum/m_492624/printable.htm
OR YOU MIGHT GO IN THIS DIRECTION.. China Silk HABOTAI Fabric 5MM WHITE 36" -By The Yard
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=380120606948
JIM
« Reply #2 on: July 10, 2009, 09:17:50 AM »
Glen, I have posted on here my use of poly-ester fabric from the local fabric store.  It used to be called jacket lining material.  It comes in a vast array of colors.  Like any covering it takes practice and patience.  The price I paid the last time I bought some was $2.99 a running yard that is 44 inches wide.  I used 6 yards on a SIG Senior Kadet back when I was playing with the dark side.
Anyway, go visit the fabric store and go to the polyester department.  Yes there are some bolts that is a heavier weave than others.  Pick the color you like and buy what ever amount you might need plus some extra.  Get a can of Stix-it or Balsa Right.  Coat the perimeter of the area you are going to cover.  Now cut material a little over size and grab your Monokote or similar iron and iron the material down pulling tight.  Try to eliminate the wrinkles as much as you can.  It is like handling dry silk.  Iron the first panel on.  Now here is a little secret to fabric, where it is going to overlalp put a coat of the heat sensitive glue over the area.
Once all panels and/or surfaces are covered, go over it with the iron.  Just get it tight.  Grab your clear dope and start painting.  If it is nitrate don't worry if the covering sags on the first few coats.  Even with butyrate I have even experienced sagging on the first few coats.  After the dope has et for a day or two you can take the iron over the covering or use a heat gun.   In the planes I have covered by the time the 6th or 8th coat of buty rate the  covering is tight.  Then grapics and more dope.  DOC Holliday
« Reply #3 on: July 10, 2009, 10:39:12 AM »
Thanks for all of your helpful replies.  I'm looking seriously at Sig Koverall.  It comes in a sheet 48" wide by 5 yds long for about $15.  That's about $5 for a running yard, pretty reasonable, it seems.  Thanks a bunch!
Glen
Glen Wearden
« Reply #4 on: July 10, 2009, 11:09:36 AM »
I used a really light rayon material once. Purchased at a material store. I was being drug along by my spouse and noticed the stuff. Incredibly sheer and very, very light. Worked OK.
Offline sleepy gomez
« Reply #5 on: July 10, 2009, 03:23:22 PM »
check www.sailrite.com  they have ripstop nylon at 1/2 oz per sq yd among other things.
Offline Bill Adair
  • AMA 182626
« Reply #6 on: July 10, 2009, 10:48:02 PM »
Hey Doc,
I covered my Kadet Sr. with Coverite, the iron on fabric version (Coverall?), and finished it with white Formula U (spray cans). Sprayed it in the garage, and the fumes ran us out of the house! The little wife wasn't too happy about that.  mw~
Flew the Kadet for ten years. Still have the wing in the garage, and it looks like new! The Kadet was heavy, but that finishing combination was really durable, just not crash proof.  ;D
