  • June 19, 2025, 10:26:01 PM
Author Topic: Covering built up fuse  (Read 1639 times)
Online James Mills
« on: July 19, 2010, 06:34:51 PM »
I'm planning to build a Junar (Bill Werewage design).  The fuse aft of the trailing edge of the wing has cut outs between the formers.  What should I cover these openings with (silkspan, polyspan, or...)?
Also, does anyone know the wing area of this design (I've read the article and didn't find it)?
James
AMA 491167
Re: Covering built up fuse
« Reply #1 on: July 19, 2010, 06:53:34 PM »
H james,
I use silkspan on the windows.  haven't tried polyspan, but it WOULD be more durable.  The Junar is in the high 600 squares.  it is basically a USA-1 wing, and the USA-1 is advertised as 700 squares.  The thin airfoil works best if kept fairly light.  Billy's were in the low-mid 50 oz. range.
Big Bear
Offline Leester
« Reply #2 on: July 19, 2010, 06:58:40 PM »
Whatcha gunna use for power ??
Leester
ama 830538
Online James Mills
« Reply #3 on: July 19, 2010, 07:34:02 PM »
Plan to use PA 61/pipe (unless I decide to crossover to the dark side and use electric #^).  I got to talk to Billy at the Nats and he said that would be a good set up, I just didn't think to ask him the wing area or how to cover the fuse sides.
James
AMA 491167
« Reply #4 on: July 19, 2010, 09:01:56 PM »
  I would probably use silk or silkspan over polyspan. I would be very concerned about getting a hole poked in it.
« Reply #5 on: July 19, 2010, 09:37:14 PM »
just iron on some SLC - then cover as usual - tough as all getout and light too!!!!
« Reply #6 on: July 21, 2010, 11:45:20 AM »
The SLC sounds like a great idea.  For some reason the polyspan we used to cover a RD-1 profile fuselage seemed to get real heavy.......
I am getting the SLC (never used it) simply because I have heard so many good things about it.  And it seems to be the lightest thing to use under silkspan.
Like Brett said, it IS easy to poke a hole in those windows! ;D
Big Bear
Online James Mills
« Reply #7 on: July 21, 2010, 03:06:15 PM »
This is a short kit I bought off Stuka and the side cutouts are laser cut as well, otherwise I probably wouldn't have cut them out.
James
AMA 491167
« Reply #8 on: August 09, 2010, 02:37:15 PM »
Really!  How much weight can be saved by cutting out a few square inches of fuselage side, and then covering with tissue?  Seems like an exercise in futility!
« Reply #9 on: August 09, 2010, 03:55:30 PM »
LL~ LL~ LL~
Hi Floyd,
Because air is lighter than wood! LL~
I know that you know Billy Werwage.  To say that he is obsessed with keeping weight down is an understatement!   Check out his P-47 "Geo Bolt" plans.  he doesn't cut windows back there, but he carves/sands the fuse sides from the inside to about 3/32nd or 1/16th.
Like it has been pointed out to me, every ounce becomes 10 ounces when we are doing maneuvers.  And weight at the tail is not usually good, since it takes a LOT more weight up front to balance everything.
GMA did the *windows* on the '57 GB Nobler, so that has been around a LONG time.
I won't argue with Billy until after I get my 4th World Championship in F2B. ;D
