Really! How much weight can be saved by cutting out a few square inches of fuselage side, and then covering with tissue? Seems like an exercise in futility!
Hi Floyd,
Because air is lighter than wood!
I know that you know Billy Werwage. To say that he is obsessed with keeping weight down is an understatement! Check out his P-47 "Geo Bolt" plans. he doesn't cut windows back there, but he carves/sands the fuse sides from the inside to about 3/32nd or 1/16th.
Like it has been pointed out to me, every ounce becomes 10 ounces when we are doing maneuvers. And weight at the tail is not usually good, since it takes a LOT more weight up front to balance everything.
GMA did the *windows* on the '57 GB Nobler, so that has been around a LONG time.
I won't argue with Billy until after I get my 4th World Championship in F2B.
