  • June 19, 2025, 11:28:50 AM
Author Topic: Composite construction question  (Read 2883 times)
steven yampolsky
« on: March 26, 2013, 02:51:04 PM »
Has anyone tried building a fuselage out of carbon fiber(no balsa sandwich, straight CF). How many layers did you use? What type of weave pattern and how thick/heavy was the fabric?
Re: Composite construction question
« Reply #1 on: March 26, 2013, 03:07:24 PM »
No, but here's what would happen if you tried:
Carbon fiber is very strong for its volume, so if you go and calculate the amount you need to make a strong fuselage ignoring the local strength you need to keep the sides from caving in, you come up with "not much".  Then you make your fuselage, and as soon as you pick it up the sides under your thumbs go "bworp*" and cave in.  To see this effect, pick up an empty pop can and squeeze gently.
So you make the sides with two or three layers: either one layer of CF with enough balsa inside to prevent the "bworp", or CF, balsa or foam, then CF, with each CF layer being half of what you used in the "bworp" example.  Result: a fuselage that is strong in all ways**, light, and insanely more difficult to build than just using balsa.
*http://en.wikipedia.org/wiki/Don_Martin_%28cartoonist%29
** when you squeeze it it will go "fleen", but silently because it is not moving.
Online Trostle
« Reply #2 on: March 26, 2013, 03:18:14 PM »
Maybe Fred Cronnenwett and/or Grant Hiestand could answer with their experience of forming molded fuselage shells  and seaplane floats from woven carbon cloth.
I know their results are quite impressive.  Strong and light.  Formed in a female mold.
Online RandySmith
« Reply #3 on: March 26, 2013, 03:22:16 PM »
and you can use types of foam for the laminate too. The CF fuse is very heavy if you only use CF
Offline Dennis Moritz
« Reply #4 on: March 26, 2013, 03:45:59 PM »
I think Windy built a Miss Ashley using a hollow carbon fiber fues and wing. Midgely(?) (sp) did the moulds. I remember looking closely at the plane at Brodak. Saw the carbon fiber webbing. It was a number of years old at that time and the dope had settled. A NY flyer is casting fiberglass fueses and wings. Sorry. Senior moment. I am forgetting his name. The results are light and rigid.
I believe Jose Modesto is making airplane parts from casting fiberglass.
« Last Edit: March 27, 2013, 04:11:11 AM by Dennis Moritz »
« Reply #5 on: March 27, 2013, 08:42:45 AM »
It's not the carbon fiber that is heavy,  it is the resin that gets heavy.
« Reply #6 on: March 27, 2013, 10:19:17 AM »
Jose Modesto has built a few.
Derek
« Reply #7 on: March 27, 2013, 10:33:37 AM »
Looking at the edges that are visible in those pictures, it looks like he's doing a 2- or 3-layer layup, although not with either the balsa or the foam that I was babbling about.  I wish he (or Howard Rush, or someone else who's done more than building car parts from fiberglass) was here to comment on what was done, since he's actually done this.
Offline MarcusCordeiro
« Reply #8 on: March 27, 2013, 11:47:02 AM »
I love that fuselage... wa$ wondering how much it would co$t to have one of those made :)
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
« Reply #9 on: March 27, 2013, 12:47:49 PM »
Marcus
Send a private message to Jose Modesto.
Derek
« Reply #10 on: March 27, 2013, 07:00:48 PM »
Derek
Thanks Derek
I had no idea they were actually available...
Will do.
Marcus
Aces High!
Offline Jorge de Azevedo
« Reply #11 on: March 28, 2013, 06:36:30 AM »
I ask a little more:
1 _ Type of fabric in g/sq.in.  or g/m2 and where we can buy it
2 -  Type of epoxy system resin
3 - Type of mold and use of vacuum
4 - Cure with or without hot in a oven
steven yampolsky
« Reply #12 on: March 28, 2013, 07:23:00 AM »
and a few more:
5) how many layers
6) what type of weave for each layer. I am thinking the top layer might need a special weave.
7) How do you join fuse halfs?
8) are the cutouts for the wing, cowl, stab, etc done before or after?
« Reply #13 on: March 28, 2013, 07:50:36 AM »
I should place this great book in the Classifides.
Loaded with information on Compisite methods of building.
Charles
Offline jose modesto
« Reply #14 on: March 28, 2013, 08:27:30 AM »
Guys I'm on a Caribbean vacation will post later the beach is great,today is a great flying day here.the trade winds are down.
Thanks D for posting photos.
SV22fuse as shown from outer layer in. .5 glass cloth,2.4 oz CFC,1/32" pre molded balsa shell,.2CFM with 2.4CFC as doubler.
Fuse as shown weight 6.5oz the fuse is made in right and left sides assembled in the mold. The only formers are for the take apart hardware.
The SV22 fuse is molded in female molds under vacuum pressure.
The .5 cloth on the exterior layer Is used to create a very smooth outer surface. NOTE the fuse can be painted in the mold you can also paint the trim.
Steve this section page 3 will give some info. Also do a search in Electric section I have posted fuse construction page 9
Jose Modesto
