  • June 17, 2025, 04:58:38 AM
Author Topic: Sig Polyester Finishing Resin  (Read 4408 times)
« on: June 07, 2017, 12:55:59 PM »
Anyone using Sig Polyester Finishing Resin?
CB
Re: Sig Polyester Finishing Resin
« Reply #1 on: June 08, 2017, 11:18:40 AM »
Quit using it years ago as it was hard to sand and also came out heavy. D>K
« Reply #2 on: June 08, 2017, 03:09:51 PM »
Z poxy, Charles, Z poxy.  Luuuuv it.  (I even often use it for grain filler on custom guitars.)
« Reply #3 on: June 08, 2017, 08:05:53 PM »
  Grossly obsolete, use finishing epoxy instead, far more stable, far less stinky, won't get as brittle, and no MEKP to make you go blind if you get it in your eye.
« Reply #4 on: June 08, 2017, 08:41:13 PM »
Finishing resin epoxies  are a  giant step above  polyester resin, but  I admit I do miss the cup melting off the sides if you mix too much, with just a tad too much hardener :-)
« Reply #5 on: June 08, 2017, 10:12:52 PM »
  Don't forget the smell, that's really the best.
     I had some sort of epoxy boil in the cup not too long ago, but it didn't melt it. It cured in mid-boil and looked just like clear foam. That's one thing I really like about EZ-Lam from Aerospace Composites - it doesn't self-heat *nearly* as much as many of the others, so you don't have to spread it out on foil to maintain the working time.
Offline Mike Ferguson
« Reply #6 on: June 09, 2017, 08:50:41 AM »
I put a mixing cup of epoxy on top of a foam cradle while sheeting a wing not too long ago. The cup actually sank completely through the cradle down to the table, making a very nice, neat hole.
EZ-Lam is definitely the way to go.
« Reply #7 on: June 09, 2017, 08:15:43 PM »
 LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~
« Reply #8 on: June 09, 2017, 08:34:30 PM »
That reminds me -- it was always the marijuana smokers that complained the most about the smell of polyester resin at my dad's shop.  Something about smokin' dope that really makes resin smell bad.
A quart of polyester resin in a gallon bucket, mixed hot, will burst into flame and set off sprinklers 14 feet above the floor.
Makes a hell of a mess, too.
« Reply #9 on: June 10, 2017, 06:09:48 AM »
And just how might you know about that, Tim? H^^  (You didn't tell us not to ask.)
« Reply #10 on: June 12, 2017, 02:55:59 PM »
Tim does a lot of dumb things so you don't have to.
« Reply #11 on: June 13, 2017, 03:17:57 PM »
Z-Poxy finishing resin is sooooooo easy to sand. Plus epoxies in general have vastly longer shelf-life than polyester resins, there's no reason not to go with epoxy.
Someplace I worked, there was a younger guy working there that had previously worked for a company that used polyester resin. The story was that they tasked him with disposing of a 55 gallon barrel of outdated polyester resin. I his youth and enthusiasm (I suppose), he mixed in the appropriate quantity of MEKP and stirred it well. After the flames and smoke subsided, he was told to seek employment elsewhere. And so, he came to work for the dipchits where I was employed.  LL~ Steve
