  • July 17, 2025, 07:44:49 PM
Author Topic: Cloth Hinge Material  (Read 1852 times)
Offline Allen Eshleman
« on: March 31, 2013, 03:01:40 PM »
I am continuing work on building an Akromaster.  I decided to make it a flapped stunter.  The flaps are thin and putting in nylon hinges will be quite a challenge.  I would like to use cloth hinges.  I only have a little bit of cloth left over from other builds.  Is there a good material that can be purchased without ordering from a hobby store which will take time?  If so, what would it be?  What kinds of stores can it be found it?
Re: Cloth Hinge Material
« Reply #1 on: March 31, 2013, 04:11:03 PM »
Allen.  Go to your local fabric store and get some Rayon Taffeta.  There are several grades (weights), so go for the lightest.  I install with Ambroid, but others have used SIGment and etc.
« Reply #2 on: March 31, 2013, 05:17:01 PM »
Can CA glue be used to fasten it?  What about dopes butyrate Dope?   What about making it look nice.  I plan to put Kolar Kote over it.
Offline Bootlegger
« Reply #3 on: March 31, 2013, 05:47:04 PM »
  Allen, I apply mine with dope, after putting two to three coats of dope on the wood, then I sand, and apply the hinges with thinned dope, as to iron on coverings I don't know if they can be applied over dope, I have never tried that method.
  Good luck, and let us  know how it works...
8th Air Force Veteran
Gil Causey
AMA# 6964
« Reply #4 on: March 31, 2013, 06:34:09 PM »
I get linen from the fabric stop and use glue as stickum. After predoping the wood, water serves as a temporay adhesive, followed by thin dope.  I've found that the water makes the cloth lay down well.   Also, if you iron the cloth with spray starch it's a lot easier to cut accurately.
Re: Cloth Hinge Material, CA material
« Reply #5 on: April 01, 2013, 04:53:03 AM »
I found some of the CA material - the stiffer material - in my scrap box.   I think that's what it's called.  Do any of you use that?   I have often thought it to be too stiff, but, it would fit in a very thin slot.
« Reply #6 on: April 01, 2013, 08:27:43 AM »
Whatever you do don't use the CA material as such for hinges.   It might work for RC, but for CL it is too stiff.   As stated go to your local fabric store,  Yes men do shop in fabric stores as they have pins, scissors and other stuff we can use.   Cut the material in strips.   Dope both surfaces that are to be hinged.   About three or so coats of dope or when it gets a slight sheen to the surface.   Lay hinge in place and brush on a coat of dope thinned down to consistency of water.    And yes iron on coverings will go over the hinges, don't use too much heat over them.
« Reply #7 on: April 01, 2013, 03:48:57 PM »
Thanks for the advice.  The CA material is out.  I'm thinking of making monokote hinges per instructions by Walter Umland.
Offline dave siegler
  • sport flier
    • Circlemasters Flying club
« Reply #8 on: April 01, 2013, 09:24:42 PM »
for cloth hinges, don't use ca.  Dope works.  But for me a heat sensitive glue like balsarite is the best.  Spread the glue, let it dry, and iron the hinges down. perfect every time
I have had bad luck with monokote hinges no matter how careful I am.  On small planes I uses sewn hinges when I use monokote.
Dave Siegler
NE9N extra class
AMA 720731
