  • June 18, 2025, 11:12:41 AM
Author Topic: Tank Painting  (Read 1204 times)
Offline Tom Dugan
Tank Painting
« on: September 17, 2007, 07:50:47 PM »
Will soon be covering and painting a Pathfinder profile.  I would like to paint the Fuel tank.  Any precautions, do's & don'ts, or advice?
Thanks Thomas
Re: Tank Painting
« Reply #1 on: September 18, 2007, 07:19:29 AM »
Thanks Thomas
Hi Thomas,
First, pressure test the tank!  (ask me how I know.) it ain't no fun fixing a leak after a real pretty paint job is applied.  ;D
I put a section of Weed Eater line in all the vents.  Then just make sure it is clean and use a good metal primer.
Offline captcurt
Re: Tank Painting
« Reply #2 on: September 18, 2007, 08:43:29 AM »
Dont forget to scuff it up some with 220 grit to get some tooth on the shiny surface
Curt
Offline Tom Dugan
Re: Tank Painting
« Reply #3 on: September 18, 2007, 09:11:33 AM »
Ive already pressure tested the tank.  I will use a good metal primer and I thought I would use an automotive type touch up paint in a rattle can.
Thomas
Re: Tank Painting
« Reply #4 on: September 18, 2007, 09:33:57 AM »
Thomas
Hi Thomas,
I did exactly that with the tank on my Tomahawk.  I used the new Duplicolor "Color Cast" (Candy) lacquer.  I didn't use a clear coat, and it has been fairly fuel proof.  But I *think* it would probably be better with some clear dope or urethane over it.
