  • July 30, 2025, 03:40:04 PM
Author Topic: Clear Coat  (Read 3149 times)
Offline Steve Keller
Clear Coat
« on: April 28, 2006, 12:22:00 PM »
I have just the finishing color and decals on a new model.  I want to blow on a coat of clear. Will polyurathane be fuel proof?  I am using an air brush with a 4 oz. jar.
Thanks........Steve
Offline RC Storick
Re: Clear Coat
« Reply #1 on: April 28, 2006, 06:13:49 PM »
What kind of polyurethane? If it is not 2 part probably not.
Re: Clear Coat
« Reply #2 on: May 05, 2006, 01:36:45 PM »
I've used Deft rattle can polyurethane to shoot on reworked wood props. Seems to be relatively fuel resistent. Or at least the props don't gum up with they get fuel on them.
Offline Oregon_Flyer
  • ACE
Re: Clear Coat
« Reply #3 on: May 05, 2006, 05:58:49 PM »
Steve,
There are several "clear" coats to choose from, however to find one that will not yellow and is fuel "proof" could prove challenging.  Most of the pros including Robert Storick, Randy Powell and Bill Little to name a few use a 2 part "clear"  I would suggest you consider this method. I am still searching for a single non tautening fuel proof "clear" that does not cost an arm and a leg, so far, nada
Marv
Re: Clear Coat
« Reply #4 on: May 12, 2006, 11:06:45 AM »
Marv,
Well, Omni is quite a bit cheaper than say, DuPont or pPg/Ditzler. Or even Matrix. I think I paid $22 for a quart of paint and about $12 for the hardner and it lasted 4 planes easily. Could probably stretch it out to 6 if conservative with paint (which I seldom am). Overall, probably no more expensive than dope and possibly a bit cheaper, depending on how may coats of clear dope you put on as topcoat. I just went through about a half gallon of clear with the new plane's topcoat.
  • ACE
Re: Clear Coat
« Reply #5 on: May 15, 2006, 03:32:50 PM »
Randy,
Right on  j1  and this illustrates the need for a show and explain step by step process right here in the Building tips.  Step up Big Guy,  we could use the training.  Also, co-authoring by the Admiral [Sparky] would certainly add to the post.  I would welcome this and believe that a cross post to the general forum directing members to this post would generate traffic like no other post.  My take is you should start by assuming we know nada and start with paint selection, reducers etc.  the whys and why nots should be in there along with the reasons why.
Marv
Re: Clear Coat
« Reply #6 on: May 15, 2006, 11:28:38 PM »
There are quite a few 2 part auto clears that we can use.  I recently got a gallon of NAPA "Econo Coat" 2 part clear.  Only drawback is that it's a 4-1 mix.  You use 4 parts clear "paint" to 1 part hardener.  But it was along the lines of a gallon of butyrate dope, price wise.  A few dollars more, but it will paint a good many more airplanes than a gallon of clear dope will.  One to two coats of clear versus 6-8-10 of dope.  I don't believe I use a pint, mixed, of the 2 part on a 60 size plane.
As to the substrate and color coats, there must be a hundred ways to get a front row finish.  It's mostly in the preparation (sanding) of the airframe.  Although there are several ways to build up the "finish", it all comes down to having everything "right" before you start painting.
Bill <><
Re: Clear Coat
« Reply #7 on: May 16, 2006, 03:38:49 PM »
Bill,
I would agree with this. Most of a front row finish is in the prep of the airframe. I have one method (generally) of building up to color coats if I'm building a plane without open bays. Another for planes, like this last one, that is mostly open bays. More air than wood exposed in that one. But however you do it, once you get up to primer/fillercoat, you have choices to make. I doubt I'll use urethane color coats again. I might, but probably not. I'll stick with lacquer and perhaps use 2 part urethane topcoat, whatever I use to build up the surface.
Re: Clear Coat
« Reply #8 on: May 16, 2006, 04:30:09 PM »
Bill,
Hi Randy,
I think I agree with you on the basecoat products.  I love the availability of colors (locally, no hobby shop around) the ease with which they go on, their lightness (need less to cover) but repairs and touch ups can get hairy!
I would rather be able to get acrylic lacquer again in North By God Carolina, but I guess I never will.  So I would really like to use *some* lacquer finish (I just like them!) but it isn't easy to do here unless I mail order.
BTW: Aaron's Satana is done with all Duplicolor Spray cans and a clear urethane automotive clear coat.  Foamie, so patching silkspan isn't a problem, and the spray cans covered quite nicely.  You just aren't in as much control over the amount used as you are with a gun or airbrush.
