  • June 14, 2025, 06:45:03 AM
Author Topic: Molding dummy engine parts  (Read 1362 times)
« on: January 19, 2012, 09:55:11 AM »
Guys,
Has anyone done a mold (vacuum or other) of an engine from plastic or other materials to be used as a dummy engine? I want to mold a Drone Diesel head and cylinder to use as dummy engines (I like the wedge look of the Drone)? What material works, what technique did you use?
Best,            DennisT
Re: Molding dummy engine parts
« Reply #1 on: January 19, 2012, 10:01:04 AM »
I'd turn it from a dowel.
Or bid on one or both of the two that are up on the 'bay, and forget this "dummy engine" stuff.
« Reply #2 on: January 19, 2012, 11:05:32 AM »
I was thinking about building an electric plane and molding a PA engine to put in the cowl.   ;D
« Reply #3 on: January 23, 2012, 09:24:53 PM »
That right there is a great idea, Randy! You could pull the "NV" out to arm it for flight.  y1 Steve
« Reply #4 on: January 27, 2012, 07:29:12 PM »
Randy : I was thinking of molding an electric engine for my PA plane!
« Reply #5 on: January 27, 2012, 10:59:54 PM »
 I'm sorry, but the whole idea seems like a large waste of time. I would say to do whatever the display model may be the justice of mounting a real engine.
« Reply #6 on: February 17, 2012, 06:42:34 AM »
Micro balloons and resin, after it's cured with the proper mix, allows for shaping just about anything. Pour it in small dixie cups, hardens into a block.
I've made interior parts and scale radial cylinders using this stuff. So has plenty of other guys that make scale parts.
Time consuming, but it's been done by plenty of scale builders. Well, R/C that I know of anyway.   n~
Charles
« Reply #7 on: February 17, 2012, 10:47:12 AM »
I want to mold a Drone Diesel head and cylinder to use as dummy engines...
That is very cool.  I wonder if there's some Pavlovian mechanism that would enable a person to smell it.
If you can make a 3D CAD drawing of the cylinder, I can get the part made by fused deposition modeling:  http://www.thecreatezone.com/The_Create_Zone/RP_%26_FDM.html
Offline Dan Bregar
  • Field Marshall
« Reply #8 on: February 17, 2012, 04:30:21 PM »
Dennis
Very cool idea !  This could catch on.  Beautiful !!!  ;)
Dan
AMA 33676
