  • July 08, 2025, 05:06:34 PM
Author Topic: center of gravity  (Read 1219 times)
Offline John KruziK
center of gravity
« on: November 03, 2007, 06:08:07 PM »
How do you determine where c/g should be on an original design?  john
AMA 874027
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
Re: center of gravity
« Reply #1 on: November 03, 2007, 08:13:59 PM »
At or in front of the center of lift, which is the high point of the airfoil. NEVER behind; AT gives max. sensitivity--or even instability.  As you move forward toward the LE, you gain more and more stability, until the plane is so stable (noseheavy) it won't do anything but fly level. A good starting place is halfway between the LE and the high point.
Correct, or dissenting opinions?
--Ray
--Ray
AMA902472
« Reply #2 on: November 03, 2007, 11:39:29 PM »
I recall (I think?) one of the gurus, perhaps Ted stating that a good starting place for the cg is at the percent of chord that equals the percent of tail area. In other words, if you have 25 percent tail area to wing area, then you could start the cg at 25 percent of the chord. At least I seem to recall this as a guideline, HOWEVER dont take my word for it without verification please,,  n1
« Reply #3 on: November 04, 2007, 12:34:13 AM »
If you have no idea, it's a good rule of thumb to have the CG in front of the high point of the wing, depending on design. I had high aspect ratio planes that had the CG very, very far aft and flew pretty well, but that's an exception. If you put it in front of the high point to start, you will probably have something that won't be so unstable that it's unflyable. Having a CG too far aft can be, uh, thrilling on a first flight.
Offline John KruziK
« Reply #4 on: November 04, 2007, 01:39:01 PM »
Thanks for the help   John
AMA 874027
Offline Circlejerk
« Reply #5 on: November 04, 2007, 02:58:07 PM »
Here's a link that will allow you to figure where to place the CG for almost any wing planform.
http://adamone.rchomepage.com/index5.htm
