  • June 20, 2025, 04:22:23 PM
Author Topic: Carving a canopy plug  (Read 1348 times)
Mike Griffin
« on: March 20, 2012, 02:48:54 PM »
Is there anyone out there in forum land who carves canopy plugs?  I will need a plug for the YAK9 D Canopy.  I anyone could help me with this, I would appreciate it.
Re: Carving a canopy plug
« Reply #1 on: March 20, 2012, 03:17:00 PM »
HI Mike,
I had decided to carve a plug from the original plans.  But I am not sure how soon I can get it done......
Online Crist Rigotti
« Reply #3 on: March 20, 2012, 04:25:07 PM »
http://www.rcgroups.com/forums/showthread.php?t=1383441
http://www.rcgroups.com/forums/showthread.php?t=489215#post5152512
Shouldn't this be in the building section?
Sorry, Crist, I didn't even think about where it was posted.......... Randy did move it for us.
Mike Griffin
« Reply #4 on: March 20, 2012, 05:55:51 PM »
It's my fault...I posted it in the wrong section....
Mike Griffin
« Reply #5 on: March 20, 2012, 05:59:19 PM »
HI Mike,
Don't worry about it Bill.   You have enough on your plate right now with your health and everything you are contending with.. I may try to carve it myself...We will see how things go...John Miller is still in Tucson so I can't do anything until he gets back and finishes drawing the fuselage.
Offline Larry Renger
« Reply #6 on: April 10, 2012, 05:01:46 PM »
If you want a really permanent mold, Here is a good system.  You end up with an exact copy of what you carve plus the thickness of your plastic.
The concept is to make a master, make a mold from that, and hard copies of the form from that mold.  You can make multiple copies from the mold.
So, carve a foam form to exact dimensions.  Fill the foam surface with spackling compound.  Sand smooth.
This is your master, not the final item.  Add a filler piece about 1/4" under your master and match it to the master.  It can have a very slight outward slope.  3 or 4 coats of clear epoxy thinned with alcohol to seal the surface and sand to perfection.  Primer and filler any imperfections. Glue this form to a plate of plywood and build a wall all around it.  NOW, give everything 3 coats of wax.  I find liquid Turtle Wax is quite good enough.  Wipe on a coat of PVA, then when dry, spray on another coat.
Make a box around the form and fill it with plaster.  When set and dry, it should pop right off.  You probably will have to destroy the walls of the box, but they will never be needed again, anyway.
Seal the plaster female with dope or epoxy and polish it to perfection.  Again with the wax and PVA.  Now you can fill the female mold with plaster and make all the canopy forms you want!
Since no heat or stress is involved with the original form, you can use vinyl tape for canopy lines and details.
I got to tour Peck Polymers once, and their final forms were metal filled epoxy.  Of course they needed hundreds of copies.
I have also used this technique to copy existing canopies.  Fill the canopy interior with plaster after applying the release agent, add the spacer underneath and proceed as above, or just use the plaster copy if you only need one or two copies.
