Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 09, 2025, 08:36:15 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Building Tips and technical articles.
Building techniques
(Moderator:
RandySmith
Carbon Landing Gear
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Carbon Landing Gear (Read 3295 times)
Alan Resinger
Trade Count:
0
Captain
Welcome to the Stunt Hanger.
Carbon Landing Gear
on:
November 24, 2015, 05:49:41 PM »
Flying with Paul Walker for the last 30 plus years tends to expose one to lots of nifty building techniques and just plain
awesome engineering tricks. A couple years ago he showed up at the start of the season with his new take apart Predator. MIke Haverly had made the take apart hardware and Paul employed a removable carbon fiber landing gear. With the new build in progress I decided that the carbon gear was just what I needed for this coming years effort. The following pictures show what I came up with.
The first picture is the Yatchenko removable titanium gear that is used on quite a few of Yuri and Andrei's models. I decided to use their mounting unit which is an injection moulded unit that has a ball with a spring putting pressure on it to hold the metal gear leg.
The next picture shows the two 1/16" unidirectional carbon that I made from material I got from Dragon Plate. These two are glued together with JB Weld. The top of the leg, which after gluing is 1/8" thick is then thinned to the same thickness as the titanium leg that comes with the removable unit.
The next picture shows that I decided to make next years ship look high tech so I vacuum bagged some 2 oz. carbon cloth on the outside and it will remain clear finished so the cloth shows.
The gear looks a lot like Paul's, but I decided to one up him and milled out about 1/32" on the inside surface. The final picture shows this neat little touch.
Nothing like sparing no expense just to put a $3 pair of wheel on your next world beater.
Alan Resinger
Logged
Steve Helmick
24 supporter
Trade Count:
0
Admiral
Re: Carbon Landing Gear
Reply #1 on:
November 24, 2015, 07:50:54 PM »
The escalating levels of one-upsmanship is nothing short of astonishing! I was trying to figure out how to do this, not yet having seen PW's. I still have some questions. Shouldn't those LG legs and fairings be hollow with foam cores?
Logged
In 1944 18-20 year old's stormed beaches, and parachuted behind enemy lines to almost certain death. In 2015 18-20 year old's need safe zones so people don't hurt their feelings.
Chris_Rud
2014 Supporters
Trade Count:
0
Commander
Reply #2 on:
November 25, 2015, 02:22:05 PM »
What is the weight savings? Looks awesome!
Logged
Alan Resinger
Trade Count:
0
Captain
Reply #3 on:
November 25, 2015, 03:50:26 PM »
Chris,
The carbon gear legs weigh 10.5g each which is less than a piece of 1/8" wire long enough for a similar length removable leg assy. The Yatchenko plug in unit is probably slightly less weight than LG blocks and plywood clips that you would need for a built up or foam wing. Then you would have to add fairings to the wire gear.
Alan
Logged
21 supporter
Trade Count:
0
Admiral
TreeTop Flyer
Reply #4 on:
November 25, 2015, 04:23:05 PM »
My Alan, aren't you the clever little elf. How's the back?
Logged
Mark Scarborough
2015
Trade Count:
0
Admiral
Reply #5 on:
November 26, 2015, 12:38:40 PM »
I like this aproach,, I wish my pracgtice field warranted use of wing mounted gear, but I must maintain my shock absorbing fuse gear,, for now
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Building techniques
(Moderator:
RandySmith
Carbon Landing Gear
