  • June 23, 2025, 01:08:14 PM
Author Topic: Carbon Gear, well I'll be  (Read 1893 times)
Offline Dwayne Donnelly
« on: January 28, 2022, 07:54:52 PM »
I couldn't save the mold this time but I'll be darned I just made my first carbon gear, still needs a bunch of trim/sanding but I can't believe how good it turned out, if I can do this anyone can.  y1 #^
One sliver though   ''
« Last Edit: January 28, 2022, 08:28:28 PM by Dwayne Donnelly »
Re: Carbon Gear, well I'll be
« Reply #1 on: January 29, 2022, 07:03:14 AM »
And the test fit before final sanding and clear coat.  y1 #^
« Reply #2 on: January 29, 2022, 12:14:47 PM »
Doug,
Really nice work. What resin did you use? I think if you made the mold from pine and finished it with epoxy it will hold up for several sets. You could even use Bondo mixed with about 30% polyester resin and it will hold up for several sets (I did props like this for quick cheap mold).
Best,     DennisT
« Reply #3 on: January 29, 2022, 02:50:22 PM »
Why not use parchment paper on the mold?   The gear looks good. D>K
« Reply #4 on: January 29, 2022, 04:14:57 PM »
Thanks guys, Doug I'm using Z-Poxy finishing resin, I will be making one more set for another plane with no plans to make anymore so I don't think it's worth the effort but I will keep it in mind if I decide to make more.
John. Never thought of parchment, I'll give it a try.
« Reply #5 on: January 29, 2022, 04:57:32 PM »
Dwayne,
Let us know how the Z-Poxy holds up. That is a easy to get resin and not as toxic as the EPON.
Best,   DennisT
