  • August 01, 2025, 09:31:00 AM
Author Topic: Carbon Fiber Veil help???  (Read 3013 times)
Offline Ralph Wenzel (d)
« on: September 20, 2006, 10:33:12 PM »
I have .2 oz. CF veil from CST Composites. I'm trying to apply it with clear dope. So far, I've found 3 wrong ways! There has to be a good method to do this, or there wouldn't be so many folks using it. Someone ? ? ?
Ralph Wenzel
AMA 495785 League City, TX
Re: Carbon Fiber Veil help???
« Reply #1 on: September 20, 2006, 10:42:54 PM »
Hi Ralph,
Just what is the problems you're having?
I use Nitrate and with the soft veil I get from Randy Smith, it is as easy as applying silkspan.
Bill <><
« Reply #2 on: September 20, 2006, 10:54:21 PM »
Maybe using Brodkak butyrate is where I'm messing up? The surface has been sanded and doped to a faint sheen.
1) I've tried just laying the veil on the surface and gently brushing new dope on - The veil disintegrates.
2) Dope the surface first and lay the CF Veil on, pressing it down gently with fingers
3) Dope the surface, lay the CF downand cover with waxed paper and then pressing that down - The veil comes off with the waxed paper
Does the veil disintegrate when you use nitrate dope? I can start over, I guess, and consider this a lesson learned several different ways. Rats!
Forgot to say, but the CF I'm using is from The Composite Store, and is very soft and pliable. The .2 oz./yd. stuff.
Ralph Wenzel
Offline wmiii
« Reply #3 on: September 20, 2006, 11:11:35 PM »
 I would suggest that you thin the dope by a lot, or  just use thinner and your  finger tips. The .2thous  as stated, is as easy as silkspan.
 Walter
walter menges
« Reply #4 on: September 21, 2006, 12:19:29 AM »
Hi Ralph,
I use very thinned out dope brushed softly over the veil. It is thinned more than 75% thinner.  After I get it stuck down,  I can brush on heavier coats.  I am *finally* getting a Werwage Vulcan done, and I used only nitrate to stick everything down, and as a filler.  There is no grain visible on the plane.
Be gentle and use very thinned dope, or straight thinner as Walter said, to stick it down.  Don't be concerned if it overlaps quite a bit, it sands so easy that it's pathetic.
Bill <><
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #5 on: September 21, 2006, 11:32:17 AM »
The trick is to have your dope brush fully saturated (almost dripping) and do not go over it more than once. I use Brodak clear thinned 50/50 for almost everything, never used Nitrate so guess I don't know what I'm missing. If you run across something that doesn't lay down just smooth it down with your finger. I slop enough dope on that even my finger doesn't distrub the fibers. As already been said if you have a wrinkle just cut it with a pair of scissors and overlap.
This is my Skylark just after applying the fillets, used .5 ounce on the fuselage sides and .2 ounce on the top and bottom. The .5 ounce was probably overkill but seemed like a good idea at the time.
Offline tom hampshire
« Reply #6 on: September 21, 2006, 12:03:06 PM »
Ralph - If the veil is as pliable as it sounds, you probably have unsized veil, which falls apart very easily.  (Sizing is a thin paste applied to the veil to give it some stiffness and cohesion.)  You can use unsized veil by keeping a jar of acetone and a jar of dope thinned 50-50 on hand when you dope down the veil.  First saturate it with the acetone, using care to keep the brush full, so it slides easily.  Then dope over the acetone, again with the brush always full.  The acetone trick makes the veil snuggle down around almost any compound curve you want.  Once I found this, I started buying the veil with sizing in it as it easier to cut and handle, and the sizing melts instantly when the acetone hits it.  Tom Hampshire
Offline wmiii
« Reply #7 on: September 21, 2006, 02:13:15 PM »
 As Ty suggested buy a really good 1" artists brush, about 15 yrs ago
I purchased 40-50 dollars worth of these brushes, still have them. They
don't shed, work really well. worthwhile investment.
 Walter
walter menges
Offline W.D. Roland
« Reply #8 on: September 22, 2006, 02:44:31 PM »
just an idea ---
why not balsarite on the balsa and then iron it on?
then spry the dope to avoid snagging?
have never used either--just a idea
David
David Roland
51336
Online RC Storick
« Reply #9 on: September 22, 2006, 06:20:47 PM »
I posted this on SSW also. But I think the vial you have is the wrong stuff. Buy some Aerospace composites .02 vial and I think your in there. Butyrate or Nitrate.
« Reply #10 on: September 23, 2006, 12:14:39 AM »
just an idea ---
David
That's an enterprising idea. I'll try it on some scrap just to see!
Ralph Wenzel
Offline Greg L Bahrman
« Reply #11 on: September 23, 2006, 10:41:36 AM »
just an idea ---
David
I'm not sure this is a good idea. But you can try it. Balsarite is for applying mylar films. When you apply clear thru the carbon fiber to the already cleared wood you want to get a good chemical bond. If this happens with the Balsarite I guess it's OK. This aids in the strength of the veil. It just seems like you are going to a lot more work than is necessary. It really is quite simple. The only thing I can think of is like Robert says, maybe the carbon mat you are using is not the right one. I would save it for applications like between the fuse doublers where it lays flat. I have some of the unfriendly stuff and it works great in flat or laminated applications. Get the right stuff and move on. Grins
« Last Edit: September 23, 2006, 02:31:09 PM by Greg L Bahrman »
Greg Bahrman, AMA 312522
Simi Valley, Ca.
