Charles. That's a dandy idea. I will try that next time I need to fit a canopy. I forsee a potential problem; after drilling holes, the canopy has to be removed and cockpit must be cleaned of balsa chips and plastic chips.
Floyd,
The violin is a great sounding instrument, especially for Blue Grass. I should have an avatar of me and my banjo.
HEY! FLOYD! YOU DRILL THE BLOODY HOLES BEFORE YOU MOUNT THE CANOPY!!
What is wrong with you?
I hope you can take a poke or two. All in good fun.
I know I sure can.
Drill all the holes in the canopy.
I have 1/32 balsa on three sides in the front, on the inside.
Tack the canopy in place with CA. In my case, at the three pieces.
Afterwards, #11 blade pokes a hole in the balsa through the hole. Dip the toothpick in CA and insert into the canopy hole.
Repeat process. Stop when you feel the heart attack and come back later.
Simple as pie.
