  • July 16, 2025, 10:48:25 AM
Author Topic: Canopies, bunch of choices there so, "What say you?"  (Read 1659 times)
« on: May 28, 2012, 05:48:12 PM »
I've placed canopies on models a few different ways, plus I'm sure we all know there are many ways to do this.
What's your favorite method of attaching a canopy. Photo if you got them?
I'll be attaching this canopy shortly. You'll see how I do mine in The New American build Thread.
Charles
Re: Canopies, bunch of choices there so, "What say you?"
« Reply #1 on: May 28, 2012, 07:53:47 PM »
I fit the canopy, cut a channel for it to seat in and glue it down. Then tape off and use some SuperFil to feather it in.
« Reply #2 on: May 28, 2012, 09:07:49 PM »
DITTO
« Reply #3 on: May 28, 2012, 09:26:04 PM »
Gentlemen,
Thanks for the reply.
Obviously, I started the Thread because I'm fishing.
SuperFil, which BTW I have no experience with, sticks to canopy material? You must scratch up the canopy where the SuperFil is. Correct?
Charles
« Reply #4 on: May 28, 2012, 09:57:25 PM »
yes to both your questions - you just need to lightly key the canopy where you put epoxy,  I usually mask it first (dry fit) then sand up to the mask line - then glue - then fill
steven yampolsky
« Reply #5 on: May 29, 2012, 05:19:17 AM »
Someone on this forum(escapes me who) suggested double taping to avoid the tiny ridge created then the tape pulled. Basically, put down tape were you expect to be, then add a second tape that extends 1/16 into the area where the filler is going. Feather the filler as expected, then when it's starting to set, pull the tape and smooth the last 1/6 by finger for a perfect ridge-less fill
Offline Gene O'Keefe
« Reply #6 on: May 29, 2012, 05:31:18 AM »
Good tip Steve !
Gene O'Keefe
AMA 28386
steven yampolsky
« Reply #7 on: May 29, 2012, 09:49:40 AM »
Good tip Steve !
I only steal good ones  >:D
