  • June 21, 2025, 07:04:24 AM
Author Topic: Wicking CA  (Read 1648 times)
Offline Kim Mortimore
Wicking CA
« on: May 22, 2012, 07:23:27 PM »
How far will the thinnest CA wick into a joint with no gaps?  I need it to wick 1/4".
Thanks.
Kim Mortimore
Santa Clara, CA
Re: Wicking CA
« Reply #1 on: May 23, 2012, 08:52:53 AM »
It will wick four inches or more, right to your hand holding the bottom of the part being "glued" and the wicking will attach your hand to that part. Been there, still do it. Damn.
Ty,
Got any pix to show us?   LL~
Kim Mortimore
Santa Clara, CA
Offline Russ Danneman
Re: Wicking CA
« Reply #2 on: May 23, 2012, 12:15:38 PM »
Oh, it will wick farther than that. It will wick four inches or more, right to your hand holding the bottom of the part being "glued" and the wicking will attach your hand to that part. Been there, still do it. Damn. H^^ D>K LL~
But it does require a right amount. Use the long tubes that attach to the spiggot, then you can put that stuff right where you need it. H^^
LL~ HOW TRUE! rd
FLY LOW FLY FAST  RISKY BUSINESS
Offline Bootlegger
Re: Wicking CA
« Reply #3 on: May 23, 2012, 01:27:02 PM »
  Well Ty ???  What about pictures??? f~
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Dick Pacini
Re: Wicking CA
« Reply #4 on: May 23, 2012, 01:36:07 PM »
Yes, CA wicks very well.  I have glued a part to my hand.  I have glued my sneaker to the floor.  (watch those drips)  I have glued leadouts to the guide tubes.  I have glued a level to a wing.  I have glued a wing to the bench.  (again, watch those drips) HB~>
This is a sticky subject.
AMA 62221
Re: Wicking CA
« Reply #5 on: May 23, 2012, 02:19:42 PM »
I make a line of pinholes. Works every time.
Charles
Offline Jim Thomerson
Re: Wicking CA
« Reply #6 on: May 23, 2012, 02:39:03 PM »
If you want really precise small amounts, put a drop of CA on a piece of plastic.  Take an appropriate size needle, and cut off the top of the eye.  Then use the needle to pick up a tiny drop of CA and put it where you want.
Offline Dick Pacini
Re: Wicking CA
« Reply #7 on: May 23, 2012, 03:06:10 PM »
Are you saying that dragging parts through the spills on the bench isn't a preferred method of applying CA? HB~>
AMA 62221
Offline KenP51
  • K Pitts
Re: Wicking CA
« Reply #8 on: May 23, 2012, 07:00:18 PM »
I have glued my hand to the plane.
I have glued my finger to my tongue. My finger was burning so I stuck it in my mouth. REAL BAD IDEA ~^ HB~> HB~>
But as for me and my house, we will serve the Lord
Re: Wicking CA
« Reply #9 on: May 24, 2012, 10:07:34 AM »
Seen a video that was done years ago on the use of the various CA's.   Can you imagine a complete build without Elmers, Epoxy and SIG type glues.   I have done it and the plane had quite a few flights before I totaled it at a contest.   No stress cracks anywhere during it's lifetime.   But, it takes extra work to do CA joints right.  Like extra holes on the ply lamination on fuse sides.   Baking soda or micro balloons for gap filling.    But, without proper ventilation the CA fumes will get to a person.   Don't ask me how I know. H^^
Oh, by the way, take a scrap balsa block that is soft.   Start putting CA on the end grain.   I have had it comeout at the other end of a six inch block of balsa.   Now moisten another block of balsa and try it.   The CA will not go too far.   It is the absence of air and sometimes moisture that causes CA to go off.   You've seen the little puff of smoke if you use enough of it. D>K
