  • August 02, 2025, 05:45:24 AM
Author Topic: KRYLON  (Read 2839 times)
Offline Bob Disharoon
KRYLON
« on: February 24, 2007, 06:35:02 AM »
can Krylon be sprayed over Aerogloss butyrate thinned dope, getting ready to finish a project..thnx,, BOB ???
Re: KRYLON
« Reply #1 on: February 24, 2007, 10:13:12 AM »
Hi Bob,
The only problem that I know of in this case is if the Aerogloss hasn't gassed off.  Lacquers cure by evaporation (for lack of a better description) and if still gassing off, the Krylon *might* not adhere as well as it should.  I would describe the condition as getting bubbles of "gas" trapped under the Krylon, which wouldn't necessarily be noticeable to the eye.....  Krylon is a mechanical bond, the Aerogloss is a chemical bond.
Bill <><
Re: KRYLON
« Reply #2 on: February 24, 2007, 02:34:33 PM »
I assume gassing off would be the same as epoxy or body filler "kicking"....so,I will give it a few days to make sure..I did a test piece of balsa directly after silkspanning and doping had dried with no ill effects. thanx,BOB
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: KRYLON
« Reply #3 on: February 24, 2007, 05:24:54 PM »
You are aware that Krylon will turn into a gooey mess as soon as it gets any fuel or even exhaust oil on it. I have used Rustolium over dope (Brodak) several times without problems but I did let it dry for several days.
Re: KRYLON
« Reply #4 on: February 25, 2007, 11:07:06 AM »
Concerning Bob's comment on the Krylon going "gooey" with fuel; the absolute WORST thing about it is that sometimes you can get a can or color or whatever that is fuel proof and then you think it all is!  That happened to my friend Larry Krauss - I had used white Krylon on a profile and it was fine, told Larry he could use it and then he puinished me by making my hold the gosh awful mess to launch it!  It's not dependable.  Now for this, I heard from a Wally World employee that Rustoleum had purchaesd Krylon - is that going to negate Rustoleum being fuel proof?
Will  HB~> ~> ~^
Offline L0U CRANE
Re: KRYLON
« Reply #5 on: February 26, 2007, 04:32:42 PM »
Bob,
to your Reply #2...
Epoxy cures as a chemical reaction. That's why we have two parts to mix together. Epoxy (and Polyester, which used to be popular - but MAN does it smell!) could cure under water, once the two components are mixed, and it skins over enough that water deosn't affect the surface. Epoxies combine into stuff that is chemically different from either the Hardener or Epoxy it started from.
Laquers are a plastic, or plastic-like, solid material that's dissolved in a solvent. The laquer dries as the solvent evaporates out of it. It doesn't go into a chemical reaction any more than salt or sugar dissolved in water does. You let the water evaporate out of a sugar or salt solution, you're right back to the same solid stuff. Ya, it might be clumped together, but it is the same chemical it was when you mixed it into water...
For solvent to 'gas off' from dope, remember the surface skins over pretty air and water tight in just a few hours at most. The solvent is pretty much trapped inside the surface, but it still works its way through and evaporates into the surrounding air. I've cut into doped models up to 20 years since after them, and still found a clear smell of the solvent!
You've probably seen articles mention to wait several weeks before buffing out a doped finish with rubbing compounds or whatever. As the solvent works its way out of the dope, the finish hardens. Most of the hardening takes place within a few weeks with most of our dope materials.
\BEST\LOU
Re: KRYLON
« Reply #6 on: March 03, 2007, 01:15:56 PM »
One of my buddies, Jerry Day, used Krylon Orange on his TF Tutor. With some care, it worked ok, but when he broke it, and needed to patch the silkspan, the troubles started. Clear dope to apply a patch to the wing caused wrinkling of the Krylon. He ended up spraying some Krylon into a jar, and using that to apply the patch dry, which worked fine. After drying, then water shrink. I don't know what the next step was, but possibly he used clear Krylon to start, or clear dope. Personally, I'd avoid Krylon.
Another buddy, Mike Haverly, has been using various dopes (Certified, Randolph, SIG, and Brodak) with Dupli-Color color spraycans from the auto parts stores. Under or over, no problems. Lots of colors available in Dupli-Color, too. Most recently, he's started using 2 part automotive clearcoat for the topcoat.  H^^ Steve
Re: KRYLON
« Reply #7 on: March 03, 2007, 01:24:25 PM »
As to the Duplicolor Automotive Lacquer:  My son, Aaron's, last trwo planes have been totally color painted with Duplicolor over whatever substrate we used at the time.  Mostly Sig Nitrate, Duplicolor filler/primer and then the Duplicolor colors.  Topped off with NAPA Econo 2 part clear.  One is a Satana the other is an Oriental.  No problems after a year or more!
I also used the Duplicolor "Metal Cast" paints (lacquers) to do a Candy Apple Red finish on my Tomahawk.  Aaron did a power on inverted landing (not his fault!) which tore a little covering and knocked off the fin/rudder.  Used Sig Lite coat to apply the patches, reprimed, and finished like original, no problems.
YMMV!
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
Re: KRYLON
« Reply #8 on: March 03, 2007, 04:59:23 PM »
Bill, is that automotive Duplicolor fuelproof by itself?
--Ray
AMA902472
Re: KRYLON
« Reply #9 on: March 03, 2007, 05:03:04 PM »
Seems to be a *little*, but I haven't trusted it altogether.  I used it without protection on the fuel tank of the Tomahawk.  It hasn't "come off", but my fingers got some red on them one time!
    • Minnesotamodeler
Re: KRYLON
« Reply #10 on: March 03, 2007, 05:47:23 PM »
If you'd stay out of the prop that wouldn't happen so often...
--Ray
AMA902472
Re: KRYLON
« Reply #11 on: March 03, 2007, 07:27:25 PM »
Offline Steve Fitton
Re: KRYLON
« Reply #12 on: March 07, 2007, 07:19:39 PM »
YMMV!
Funny you mention Duplicolour paint Big Bear.  Tonight I was standing in an Autozone store, wondering if the Duplicolor Grey primer/filler was a lacquer based primer suitable for stunt use.  Was looking for the Sherwin Williams primer but neither Advance nor Autozone carry it around these parts.  I guess looking at Napa is next on the list.
Re: KRYLON
« Reply #13 on: March 08, 2007, 07:46:05 AM »
Hi Steve,
The "standard" Duplicolor is lacquer.  They make big cans of Acrylic Enamel, but the label is different, and it says Acrylic Enamel ingood sized letters on the front.  Otherwise it is lacquer.
All their primers (AFAIK!) are lacquer based.
Sig Lite Coat will go over Dulpicolor with no problems.  This allows infinite trim color options if you're doing a dope finish!
Bill <><
