  • June 15, 2025, 07:39:51 PM
Author Topic: CA not working like it shood?  (Read 3219 times)
« on: March 29, 2022, 02:06:44 PM »
Anyone else experience CA, the ultra thin, not working like it normally does? Slow, so slow?
I believe I read something some time back about this?
Charles
Re: CA not working like it shood?
« Reply #1 on: March 29, 2022, 02:33:47 PM »
Charles
Yes, my last two bottles of BSI set way too slow and as a result ran into places it shouldn't have or found fingers to stick to that were supposedly out of harms way.
The new stuff I ordered from Starbond sets like normal.  Haven't noticed any strength loss, just SLOW.
Online Motorman
« Reply #2 on: March 29, 2022, 02:52:54 PM »
What temp is the shop?
« Reply #3 on: March 29, 2022, 04:20:07 PM »
« Reply #4 on: March 29, 2022, 05:35:13 PM »
My shop is currently the kitchen countertop.  77 degrees in the house.
Silk dry with CA didn't work all that well, the CA wouldn't set up. It was a struggle, but I got through it.
Charles
Online Motorman
« Reply #5 on: March 29, 2022, 05:56:58 PM »
I've had the same problem, thought it was the cold, just have to use kicker I guess.
« Reply #6 on: March 29, 2022, 06:10:07 PM »
Motorman,
Yes, I used the kicker but that got the silk wet. It was a struggle but I did manage to finish the stab and elevator bottom on one side of the model.
Photo tomorrow possibly.
Charles
« Reply #7 on: March 29, 2022, 07:36:05 PM »
Charles,
When I was covering the Barnstormer wing with silk using the CA approach I had to try several brands. It seems that if the CA has been sitting around for a while it kicks slower (except for fingers). It seems some of the stuff just took longer than you want to use it as pins. I found the CA from Home Depot in the small tubes worked well and was fresh so it kicked good.
Best,   DennisT
« Reply #8 on: March 30, 2022, 10:27:25 AM »
Charles,
Best,   DennisT
Den,
I think I'll stop killing myself and pick up a fresh bottle. The "drop" should hold immediately.
I've had CA get "solid" as a rock, just sitting on a shelf.
Thanks for the reply.
Charles
« Reply #9 on: March 30, 2022, 01:00:41 PM »
As I forgot where I left my bottle of CA, I bought a new bottle of Gorilla thin CA.  I am thinking what a waste.  Even breathing on it did not help.  About a minute later it finnaly went off.   I did find my bottle Of CA in nthe house that I took in for a project for the wife.   It works great. D>K
Now if I still smoked there probably would be no problem as That is how I would set CA off way back then. H^^
« Reply #10 on: March 30, 2022, 06:51:06 PM »
Managed to get through the bottom, but waiting for the CA to dry and bite, takes a bit of time with my current bottle of CA.
I never purchased CA at Home Depot before but I'll give it a try. Or Hobby Lobby. That's all we have.
