We are all familiar with trailing edges that consist of two pieces of sheet with a cap at the back and small blocks to carry flap hinges.
Most of the plans that I have show the cap at the back—often 1/8" thick and 1/4" or 3/8" wide—shaped to the airfoil taper and the TE sheeting applied over the top and bottom. It strikes me that trying to taper the TE cap when all the support is the glue holding the cap to the backs of the ribs is fairly risky and fitting the TE sheets first with the cap glued to the TE sheets and the ribs will be stronger and the cap easier to taper.
How do other people do this?
And I am already building on tubes so please don't suggest Millennium Wing built up LE and TE or anything that will not work for a wing that already has all the ribs main spars and LE fully assembled on the tubes.
Cheers
