  • July 09, 2025, 03:15:04 AM
Author Topic: Built up flaps  (Read 2000 times)
Offline Curare
Built up flaps
« on: January 13, 2014, 06:30:26 PM »
Hey guys, probably a simple question, but I'd like some input nonetheless.
When making built up flaps, is it better to do a zig-zag warren truss style arrangement or a set of chordwise ribs?
I would have thought a warren truss would be better for torsion, no?
Greg Kowalski
AUS 36694
Online RC Storick
Re: Built up flaps
« Reply #1 on: January 13, 2014, 06:41:09 PM »
better yet X them but I say warren truss
Offline Chris Wilson
Re: Built up flaps
« Reply #2 on: January 13, 2014, 07:05:03 PM »
I have seen blue sheet foam used in built up flaps with good success and kinda negates any further need for internal bracing.
Just a thought here.
MAAA AUS 73427
Offline Curare
Re: Built up flaps
« Reply #3 on: January 13, 2014, 07:07:14 PM »
You mean xps foam, yeah? I have a pile of it in my workshop.... VD~
Greg Kowalski
AUS 36694
Re: Built up flaps
« Reply #4 on: January 13, 2014, 07:13:29 PM »
I only know it by the name "Depron."
But have seen Oz fliers use it with balsa laminations and it turns out extremely flat and very stiff when finished.
MAAA AUS 73427
Offline Curare
Re: Built up flaps
« Reply #5 on: January 13, 2014, 07:56:07 PM »
AHA! I just gave away a pile of depron!
Bugger!
Greg Kowalski
AUS 36694
Re: Built up flaps
« Reply #6 on: January 14, 2014, 07:58:45 PM »
Flaps aren't thick enough to have a lot of air in them.  I've found that ribs and glue can easily equal the weight of any wood saved.  Physics says that flat flaps(no taper) with square trailing edge are stiffest.  Especially if covered with light carbon fiber.  Do a scientifical esperiment and build a test piece first and measure how stiff it is compared to plain balsa or built up.
Phil C
Re: Built up flaps
« Reply #7 on: January 14, 2014, 08:17:20 PM »
The JCT is coming to town.
We're plenty stiff from the flaps on down.
