  • July 03, 2025, 12:49:04 PM
Author Topic: Leather Fillets  (Read 6603 times)
Offline Larry Renger
Leather Fillets
« on: January 17, 2016, 08:34:39 PM »
Quick, easy, smooth, takes paint like a sponge! Never any separation.  ;D
I did the vertical and horizontal tails in about 5 minutes. Spread a line of Sigment or Amberoid into the joint, lay the fillet on and smooth it down with a rounded dowel. Done!  #^
Fillets available in a wide variety of radii. They are extremely consistent in radius. Soft and able to follow contours easily.  What's not to like? Well, they do have to be ordered, your LHS no longer carries them. Also, they are a bit on the expensive side, but not, say, compared to a state of the art stunt engine!  H^^
Re: Leather Fillets
« Reply #1 on: January 26, 2016, 01:37:51 PM »
Never tried this.  Maybe I'll try it on my next build.  What are sources for these fillets?  Any good tutorials on how not to mess up good leather while in the learning phase?
Mark
Offline dennis lipsett
Re: Leather Fillets
« Reply #2 on: January 26, 2016, 05:34:30 PM »
Walt Umland was a good source and he might have some stock left. Send him an E Mail and ask.
Dennis
Re: Leather Fillets
« Reply #3 on: January 27, 2016, 07:30:43 AM »
Freemansupply.com is the source I used.  H^^
Offline Phil Krankowski
Re: Leather Fillets
« Reply #4 on: January 27, 2016, 03:33:20 PM »
What size(s) would you recommend?
Phil
Re: Leather Fillets
« Reply #5 on: January 27, 2016, 09:30:07 PM »
100 foot minimum?!?  That'd last me three or four lifetimes.  Any idea how much a 100 foot bundle is?  I don't see an order page on their site to pre-look.
Mark
Offline Jack Pitcher
Re: Leather Fillets
« Reply #6 on: January 27, 2016, 09:49:00 PM »
Jack Pitcher
Vortex Stunt Team
AMA 65309
Offline Fredvon4
  • Central Texas
Re: Leather Fillets
« Reply #7 on: January 28, 2016, 08:02:00 AM »
I build mostly 1/2a and 36" to 44" wing span planes mostly profile fuselages, none of them for competition or static judging and would like to try my hand with leather fillets
What sizes should I consider?  My usual micro balloon / epoxy fillets are shaped with cove shaped broken blade and wet finger
Another question is on pre monocoated surfaces will the method work on top of the covering or do I need to peel back to bare wood using the leather?
Fred von Gortler IV
Re: Leather Fillets
« Reply #8 on: January 28, 2016, 08:09:46 AM »
I suppose you could put the fillets over film covering if you used contact cement, but I would just strip back the covering.
Purchasing the fillets could be a club activity. Or sell the excess in the classified section here and do everyone a favor.
Re: Leather Fillets
« Reply #9 on: February 01, 2016, 08:51:42 AM »
Here is how I fillet around a sharp leading edge. I use a separate piece of the material, trim it as shown in the photo, and soak it in water to get it really pliable.  H^^
Re: Leather Fillets
« Reply #10 on: February 27, 2016, 10:53:45 AM »
The model finished up great with a transparent blue epoxy finish and Microlite film over lightweight polyspan on the wings. Photo in the Ringmaster thread in the main forum.
Re: Leather Fillets
« Reply #11 on: February 27, 2016, 06:37:16 PM »
How much does a foot weigh ??
Re: Leather Fillets
« Reply #12 on: February 29, 2016, 08:14:29 AM »
The large fillet material comes in at .112 ounce per foot.
Re: Leather Fillets
« Reply #13 on: March 09, 2016, 09:51:36 PM »
The leather fillets worked perfectly. Not a hint of separation, smooth surface transition. Light weight added to the structure, what's not to like?
