  • June 19, 2025, 01:02:48 AM
Author Topic: BUILDING CS22 COMPOSITE BALSA SHELL FUSE  (Read 8703 times)
Offline jose modesto
« on: May 24, 2013, 04:24:52 PM »
I have received inquiries on how i built the CS22 fuse for the plug in models.
the fuse is constructed of 1/32" contest balsa with glass cloth and 5.4oz/sy carbon fiber cloth as a doubler
1) glue two pieces of 1/32"x4x48" contest balsa sand seams flat, wet and mold over male Buck (fuse)
The rest of process see photos
photo #1 Mold,formed balsa wood and Vac Bag
#2 epoxy and filler
#3 first layer cloth
Jose Modesto
Re: BUILDING CS22 COMPOSITE BALSA SHELL FUSE
« Reply #1 on: May 24, 2013, 04:31:43 PM »
#4 CFC interior doubler 5.4 oz/sy used for this fuse. Typically i use 2.4oz/sy CFC  NOTE:since i have built numerous electric models using this fuse construction and always requiring nose weight i used the heavier cloth from CG forward.
#5 CFC Triple as this will have forward motor mount. (Hunt Mount)
#6 Wax paper to protect the bag. this allows for multiple bag use,
Jose Modesto
« Reply #2 on: May 24, 2013, 04:41:17 PM »
photos
« Reply #3 on: May 24, 2013, 04:44:59 PM »
added photos
« Reply #4 on: May 24, 2013, 04:46:40 PM »
added photos
« Reply #5 on: May 24, 2013, 04:47:55 PM »
Added photos
« Reply #6 on: May 24, 2013, 05:25:16 PM »
photo of completed CS22  is my modified SV22
Offline MarcusCordeiro
« Reply #7 on: May 24, 2013, 05:47:19 PM »
Awesome!!
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
Offline James Mills
« Reply #8 on: May 24, 2013, 05:55:58 PM »
Thanks for posting this Jose, very cool.
James
AMA 491167
« Reply #9 on: May 24, 2013, 09:00:29 PM »
That's really neat. Light and structurally sound. I like it.
Offline Matt Colan
« Reply #10 on: May 25, 2013, 12:35:59 PM »
Looks wonderful Jose!
« Reply #11 on: May 26, 2013, 10:59:25 AM »
Thanks guys for the kind words.
The CS22 fuse can be used to build multiple models.Since the fuse is hollow at this stage you can draw on fuse side the model of your choice. SV22,Impact, Trivial pursuit,Pattern Master ETC.
Photo sequence
The given horizontal line is the line through wing,since the fuse started life as a SV22 the motor thrust line is 3/4" above wing. Note if you are building this model as an Impact lower wing centerline 1/8" for a 7/8" wing bellow motor thrust line.
The CS22 fuse shown is being built for an electric model. the fuse can also be used to build a gas model.
Jose Modesto
« Reply #12 on: May 26, 2013, 11:01:11 AM »
added photos
« Reply #13 on: May 26, 2013, 11:10:43 AM »
PHOTOS gas fuse.
gas fuse 8oz. electric fuse 6.5 oz
« Last Edit: May 26, 2013, 05:18:57 PM by jose modesto »
Offline RC Storick
« Reply #14 on: May 26, 2013, 02:14:24 PM »
Those look really good Jose!
« Reply #15 on: May 26, 2013, 03:02:05 PM »
Jose,
So, you make the plugs with formers and foam then glass, right? Then you make the mold. So, do you vacuum bag or do you use the plug in a compression mold?
« Reply #16 on: May 26, 2013, 05:10:10 PM »
Randy the former and foam is only for the oval fuse. The Impact,SV and Saturn plugs and molds for fuse were made from individual male plug(fuse) the fuse has a parting line that runs the lengh of the fuse.
first and second photos  show 2 different methods for creating the parting line
Third photo is the removal of famale mold from the male plug(fuse)
see photos
jose
« Reply #17 on: May 26, 2013, 05:14:33 PM »
Added photos
#1 female mold and male plug(fuse) for the paul ealker Impact
#2 female mold in the cofin ready for plaster emclosure
#3 mold in plater with SV fuse female mold ready for the same
Jose
Offline Doug Moon
« Reply #18 on: May 27, 2013, 10:33:02 AM »
Jose,
What plaster are you using?  I tried using plaster on one i made years ago and as it dried it shrunk and cracked and wasnt usable?  Have you run into that problem?
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
« Reply #19 on: May 27, 2013, 04:43:23 PM »
 Doug. The plaster is plaster of Paris  the trick is to use one or two layers burlap cloth as a binder for the plaster.
I put a layer of plaster+1/2" then burlap, add plaster to complete the mold.
Note: the plaster is used to hold the female mold.
Jose
Offline David_Stack
« Reply #20 on: May 29, 2013, 10:44:21 AM »
Good Afternoon Jose;
  Impressive work!  I don't see any sign of a 'joggle' to establish a flange, are you using seaming tape to join the two halves at the parting line?
r/
« Reply #21 on: June 11, 2013, 06:12:10 AM »
up date on CS22 fuse
The new fuse is to be used on a set of built up wing and foam tail from a previous model.
The original model was built as one of two models for the 2012 Nats. this model had suicidal tendencies.
The model posted crashed with out leaving the paved circle. the lines got caught on the concrete, model turned into the circle and proceeded
to tear the nose off.
repaired the model, second incidence the model strapped into rear seat, seat belt attached. a set of construction plans fell beside the front seat and activated the front seat to decline back. You know what happens next,seat crushes the fuse at same location of repair.
repaired model again.
photo of original model attached
second photo Batt hatch
Jose Modesto
« Reply #22 on: June 11, 2013, 06:14:29 AM »
add photos
Evil model being deconstructed
Carbon rods through fuse, these are used to allign and support Batt trey
« Reply #23 on: June 11, 2013, 06:17:58 AM »
add photos
Batt Hatch with magnets
« Reply #24 on: June 11, 2013, 06:19:58 AM »
add photos
Impact Fuse with Batt hatch and magnets
new model fuse wing and tail
new fin Note:designed and shaped by Jim Damarell
« Last Edit: June 11, 2013, 10:16:04 AM by jose modesto »
« Reply #25 on: June 11, 2013, 07:25:59 AM »
I really like this thread.
Thanks Jose...
Marcus
Aces High!
« Reply #26 on: June 11, 2013, 08:23:50 AM »
Very nice work Jose! I want to talk to you at the Nats about some carbon molding. I want to learn how to make gear, wheel pants, spinners, and maybe props one day. Cant buy them anywhere anymore.
Derek
« Reply #27 on: June 11, 2013, 10:13:49 AM »
Thanks Marcus. Derek we will talk at NATS
Assembling model into one piece today.
Jose
« Reply #28 on: June 11, 2013, 10:34:37 PM »
Model in one piece
 photo 1fuse and wing resting in jig
#2 gluing lower fuse
#3 first test fit
« Last Edit: June 11, 2013, 10:58:44 PM by jose modesto »
« Reply #29 on: June 11, 2013, 10:36:04 PM »
add photos
#1 rough cut balsa stab doubler waiting to sand and mate to stab
#2 model in one piece fin resting on fuse. i may extend fuse with 1/2" balsa at fuse tail post
#3 mode lin one piece front view
« Reply #30 on: June 11, 2013, 10:41:33 PM »
add photos
#2 front end  you can see carbon fiber rods  used to align batt trey.
« Last Edit: June 11, 2013, 10:59:50 PM by jose modesto »
« Reply #31 on: June 12, 2013, 04:50:36 AM »
This plane looks awesome Jose. Look at all those ink lines...
Derek
« Reply #32 on: June 12, 2013, 05:03:22 AM »
Ink inspired by Gene Martine. A little excessive.It all started with trying to conceal the batt hatch with the inklines at fuse top.
Ink applied with 2 size sharpi markers. Dint want to clean radiograph pens. (lazy)
Thanks Derek
Jose
« Reply #33 on: June 13, 2013, 08:37:23 AM »
Thanks Derek
Jose
If you need to clean dried out Rapidograph pens and do not want to work, just put the tips into a bowl of  Simple Green, full strength, it will work fast, and better than anything you have seen.
« Reply #34 on: June 13, 2013, 07:52:18 PM »
Derek
Hi Derek
I can teach you how to make  CF Props, Pants, Spinners and other items, CF gear is still available and will be for a long time to come, other items like props are dissapearing.
« Reply #35 on: June 13, 2013, 08:52:14 PM »
Regarding plaster, when I worked at Boeing's Mock-up FG shop in '65, we used some plaster, but mostly as a finish layer over "HydroCal". The HydroCal was often reinforced with horsehair or "excelshire" (wood fiber strands). I think the reason we used it was strength and reduced shrinkage problems. I am not at all sure that any of this stuff would still be available, but it worked well and we did make some nice parts.  H^^ Steve
« Reply #36 on: June 14, 2013, 06:34:31 AM »
Hi Derek
I know Randy and I plan on working with you on this stuff too. It is something that interests me very much.
Derek
« Reply #37 on: August 05, 2013, 07:13:14 PM »
Airplane current status.
paint job not completed. This was one of the model being built for the Nat's
Model weight as shown 58oz  real good flyer with killer corner. The small flaps and relatively low weight helps in the tigh corners.
Jose Modesto
« Last Edit: August 06, 2013, 06:17:52 AM by jose modesto »
« Reply #38 on: August 05, 2013, 07:14:44 PM »
Add photos
