  • August 01, 2025, 09:59:19 PM
Author Topic: New Plane Plan (PHOTO)  (Read 2009 times)
Online RC Storick
« on: September 24, 2006, 04:58:55 PM »
After flying the contest today I got home and took a nap. After waking up I got enthused again and I decided to start a new airframe. For ease of building it will be a beamer. I have nothing started or drawn. I am going to show how a plane can come from concept to reality in less than a month. This airplane will be of the Viper vintage (look) but new aerodynamics. Right out of my head just like I use to.
The shop is clean and I am waiting on wood for skins for the P-47 so progress has ceased on that plane. Why sit idly by. I will post some photo's later tonight. Start of the newly designed Viper on 9-24-06 projected completion date 10-31-06.
It should prove to be interesting.
First shot is what I am going to build from. PLANS
The 1 9/16 and 1 1/8 measurements are the spar ,the 7/8 measurement is the rear spar.
2 7/16 root thickness and 2 inch tip thickness. Root cord 10 3/8 tip 7 3/4 Beam wing
10 inch nose and 17 inch tail moment.
« Last Edit: September 24, 2006, 07:48:48 PM by Robert Storick »
Online Crist Rigotti
Re: New Plane
« Reply #1 on: September 24, 2006, 07:25:47 PM »
What size engine Bob?
Online RC Storick
Re: New Plane
« Reply #2 on: September 24, 2006, 07:36:08 PM »
PA .40 long stroke
Re: New Plane Plan (PHOTO)
« Reply #3 on: September 24, 2006, 08:50:50 PM »
I decided to build a plane for P-40 and am doing much the same thing. It will definately  be a one off. I have the wing rib template from another plane and have started cutting  balsa, but it will probably take more than a month. I need to order some supplies.
« Reply #4 on: September 26, 2006, 05:51:59 PM »
Is it gonna have a pilot??? <=
Online RC Storick
« Reply #5 on: September 26, 2006, 06:03:57 PM »
Yeah at the end of the lines.
« Reply #6 on: September 27, 2006, 08:59:38 AM »
Perfect! **)
