  • July 31, 2025, 03:18:36 AM
Author Topic: Macchi-ized Fancherized Twister Build  (Read 36087 times)
Offline Jake Moon
« on: March 26, 2024, 09:58:09 AM »
Just what we all need, another Twister thread!
I have a single plane that I fly regularly. It's a Brodak Vector 40 ARF with an LA 46—excellent stuff. I'm not working for the time being and have the control line bug, so I've recently learned the pattern and put in 8-12 flights a week. Knowing that any day could be that Vector's last, I figured having a backup plane wouldn't be the worst idea. Here's the Vector and our flying setup in a park by the water:
Though my Twister is under construction, it's already flown a lot. I bought a couple SIG Twister kits from a hobby shop in Japan and had them sent to my mother in Tokyo. On a recent trip to visit her, I took the kits back with me to Singapore in my checked luggage. We live in a small (by American standards) apartment, so I've been building this plane on our desk, the floor, and our balcony. In order to build a straight wing but also not destroy our desk, I went to our local hobby shop and bought a few pieces of heavy, 6.5x100x1000mm C-grain balsa to use as my jig. I cut about 40 tabs and glued them to the wood slabs and the trailing edge and spar. Here's the setup mid-build:
I cut the half-ribs from extremely light 1.5mm wood. Good, light balsa is easy to find in Singapore and surprisingly cheap. It might be the only cheap thing here! This is fortunate, as the kit wood is very heavy.
When I build scale models, I make things more complicated than they need to be in the quest to do something different or just to see if it'd work. Turns out that is also the case in aeromodelling. I wanted to go for a warbird that wouldn't look absolutely ridiculous with a long nose and a straight, mid-mounted wing. And I wanted to be different than the usual P-51s, Zeros, P-40s etc. I landed on the Macchi C.205 Veltro. The moments are roughly similar, the fuselage is shallow, so the mid-mount won't be as weird, and the wing doesn't have a huge taper. And I'll get to do a fun livery.
Here are some of the Fancher modifications (before filling). I replaced most of the aft fuselage in an effort to reduce weight (the kit fuselage wood was around 15 lbs/ft).
After each building session everything goes back into my closet. Some details in this photo show that I made the fuselage narrower to make it more scalelike and the 3-inch bellcrank instead of the 4-inch one that the plans call for but I can't get a hold of here.
Covering options are also limited here. I have some polyspan-like covering made by KM Co. in Japan. I've never used this stuff before so I made a little mockup to see if it'd shrink and soak up dope. It came out pretty good! Shrinks drum tight and strong. Like polyspan it doesn't sand well. And unfortunately it's very heavy. For 1 wing the covering alone weighs 1.2 ounces! So I only covered the wings, rudder, and elevators.
My wife took a picture of a late-night doping session on the balcony. Waterbased EZ Dope is the only dope available here. So far I like using it.
Wing covered. Eagle-eyed viewers may note that the bays are off by a half. I cut the leadouts too short and ended up with an outboard wing 1.5 inches longer than the inboard. So I sawed off half a bay from the outboard. Whoops.
Assembly time. We don't have a table or desk large enough for this, so I'm building it on the floor and using the joints in the hardwood as the centerline. It's working though my knees are getting sore! I enlarged the stab per the plans, though cutting away some for the rounded look probably reduced the area back to the kit size. I made a built up stab that warped, so I made a replacement out of 6.4-pound, C-grain, 6.5mm wood.
And then today I glued in the wing! This is my favorite part of the build and it took all of my self-control not to pick it up and look at the assembled airframe while the epoxy still dried. I have realized that something is slightly off—I could only get the measurements within 2mm of each other on each side. The wing is at least straight to the fuse and level to the floor. I'm hoping that'll be close enough.
More updates will follow soon. As it sits, the airframe consisting of the covered wing, doped fuse, stab, and rudder is 19.2 ounces. Power depends on a few things. If I crash the Vector and need to get the Maccherized Twister flying well ASAP, I'll use the LA 46 from the Vector. If it comes out too heavy, I'll go for the LA 46 as well. If I don't plant the Vector and can take my time, and the Twister is light enough, I have a new K&B .28 Sportster that looks cool.
Thanks for taking a look.
Jake
« Last Edit: March 26, 2024, 11:05:36 AM by Jake Moon »
Offline Crist Rigotti
Re: Macchi-ized Fancherized Twister Build
« Reply #1 on: March 26, 2024, 01:58:16 PM »
Thanks for the report!
« Reply #2 on: March 26, 2024, 07:01:40 PM »
Looking good.  I love the plane you are patterning it after.  I designed a PA ship around it back in the 70's.  Never built it.
Online Dave Hull
« Reply #3 on: March 26, 2024, 09:45:24 PM »
Nice!
The best thing about storing the plane parts in the closet between sessions is that your clothes smell like balsa wood all day.... Waaay better than a dryer sheet!
Offline Richard Fleming
« Reply #4 on: March 27, 2024, 04:11:46 PM »
Keep up the great work and stay with it! You are getting there.
AMA 83080
AHRMA 9827
Offline Matt Colan
« Reply #5 on: March 28, 2024, 07:29:27 AM »
Brings me back to the days of building in my dorm room during college. Great report as always!
« Reply #6 on: March 28, 2024, 11:40:22 AM »
Did your roomate complain most about the smell or the dust?  I taught mine how to hand launch and pit for combat.  LL~
Offline Jake Moon
« Reply #7 on: April 01, 2024, 09:38:33 AM »
Thanks to everyone for the replies! The theme of this update is sanding. I do almost all of the outside jobs (sanding, filling, doping etc.) at night when the weather drops from 95 degrees and 90% humidity to only 83 degrees and 90% humidity.
Balsa filler is not available in Singapore, but I found a substitute in model railway putty. I looks, weighs, and sands the same, and is annoying to apply. I think it's the same stuff. After filling, I sanded the filler sections with 240, 320, 400, 600, then 800-grit sandpaper. Non-filled areas started the process at 400. Here's the airframe now.
I foolishly used the filler for filets as well. This proved to be impossible to get perfect as I kept gouging the filler or getting it uneven or standing too much of it away. Eventually I just called it a day. Part of the intent of this project was to learn how to build, and I certainly learned here.
I made the fuselage/rudder transition piece (what on earth is that thing called?) from 3mm balsa and glued it in place.
Here's a little detail that I'm pretty pleased with: the shroud that the tailwheel would retract into during flight.
The fuselage fun and filler added 0.4 ounces, so the airframe now sits at 19.5 ounces.
« Reply #8 on: April 01, 2024, 02:36:10 PM »
Jake, you should be able to get wood filler at a hardware store.  "Plastic Wood" works great but is a bit heavy.  Min-Wax makes a light wood filler that is pink.  It turns pine color when it dries.  It sands really well.  Love Twisters.  I will warn you that they don't glide well after the engine quits which makes the F2B landing a challenge!
Keep it up - Ken
Offline Matt Colan
« Reply #9 on: April 01, 2024, 03:40:56 PM »
Excellent work Jake!!
Offline big ron
« Reply #10 on: April 07, 2024, 01:54:37 PM »
Very nice work Jake
John Blanchard
Brusly, Louisiana
 AMA 1054488
Offline Jake Moon
« Reply #11 on: April 22, 2024, 08:28:39 AM »
Thanks for the kind comments. A big update - we have paint! I went for the standard sand with green squiggles that the Italians employed on most C.202s and C.205s. I used some Nippon Paint rattlecans from a hardware store as that is all I can manage with my setup at the moment. The green is just acrylic art paint applied with a brush. In the future I'll certainly need to figure out some sort of airbrush system as this isn't great paint and is quite heavy. Since the color covers well, I did not prime the airframe. Even still, all the color added 3.5 ounces. Ouch!
The airframe is now 23 ounces. My new target number for the completed plane is 44 ounces. I recently bought a Brodak .40 that I'll use instead of the K&B .28 I had planned to used, so that should give me a whole lot more power for minimal weight gain.
My next step will be to design some vinyl applications for the roundels and squadron markings. We live near an art school so there are about a dozen print shops who can cut vinyl within a 10-minute walk.
Thanks for looking,
Jake
Offline James Mills
« Reply #12 on: June 03, 2024, 01:44:09 PM »
Looks nice Jake.
James
AMA 491167
« Reply #13 on: June 15, 2024, 03:04:01 PM »
The Italian camo  looks good Jake.
AMA 83080
AHRMA 9827
Offline Jake Moon
« Reply #14 on: January 14, 2025, 07:18:48 AM »
I never finished this thread, but I did finish the plane.
I designed some basic markings on Inkscape and had a print shop cut them from vinyl for me. One of the benefits of living near an arts school. On the fuselage is a "Merlion," a Mermaid/Lion hybrid that is a symbol of Singapore. It came out pretty light—41 ounces. Here are some photos just a few minutes before my its first flight. I'm glad I took these.
And here's why I'm glad I took those photos:
On the third flight I did a couple basic maneuvers and all was going well. Then I tried a horizontal 8 and the motor quit right at the outside-to-inside intersection. I did what I could but couldn't get it turned back over in time.
The damage was pretty significant. The fuselage was split in half horizontally and cracked all the way around the wing root. The flaps broke as well. But the wing survived. So I put it all back together with epoxy and fiberglass cloth. I glassed pretty much the entire fuselage and brushed an extra coat of epoxy over the nose in case there was some damage further inside that I couldn't see. Dunno if that would do anything though. But the plane is still straight, and after removing the 2.5-inch spinner, only half an ounce heavier. I don't have any close up photos since the repair (it's pretty ugly), but it flies again. It still isn't completely trimmed, but it should do the job of letting me get more patterns in. I never figured out why the motor quit, but after replacing all the fuel tubing, cleaning out the spraybar, and replacing the glow plug, the motor runs great.
Here's the repaired plane with the regular flying group.
And here's how I get home from the field—taking the plane on the subway!
Thanks for looking.
« Reply #15 on: January 16, 2025, 09:16:47 PM »
The subway to go flying!  Has to beat the Dallas traffic!
Online Dave Hull
« Reply #16 on: January 18, 2025, 12:47:43 AM »
Very cool story! Thanks for sharing that. That Castoldi is one of my favorites....
