  • June 18, 2025, 07:11:53 PM
Author Topic: Cold weather and epoxy  (Read 1560 times)
Offline Gordon Tarbell
« on: January 01, 2018, 07:18:42 PM »
Getting ready to build engine /fuselage crutches . Dug out my Zap brand 30min epoxy and the resin part is nearly solid is it ok to heat it up in warm water to get it back into a viscus state?Then mix as per normal and use it or is it no good once it gets to this nearly solid state in the container? I keep the house at about 63* to save $, hope I haven't killed a nearly new bottle of epoxy.
Gordon Tarbell AMA 15019
Online Gerald Arana
Re: Cold weather and epoxy
« Reply #1 on: January 01, 2018, 07:24:33 PM »
Gordon,
I heat up my epoxy all the time. Some times in water, other times with the head gun. Works perfectly. Also when I apply it, I heat it up to cause it to flow better.
Cheers, Jerry
« Reply #2 on: January 01, 2018, 07:25:21 PM »
    It will probably be fine once you warm it up, but you definitely want it to cure at a normal or slightly elevated temperature, 63 won't cut it.
« Reply #3 on: January 01, 2018, 08:08:28 PM »
OK , I will put an old 60watt incandescent light I have on it and up my SMUD bill a bit.  Thanks for the advice , I have most of the stuff cut out and in kit form. Time to start gluing the bits and pieces together.
Offline Lauri Malila
« Reply #4 on: January 02, 2018, 02:35:26 AM »
Put the bottles in hot water for a while, that way you won't overheat them. When gluing, it's really worth the trouble to let it cure in elevated temperature (50..70C), especially with faster epoxies & hardwood. That way you'll end up with nearly 50% stronger seam.
