  • July 08, 2025, 05:07:18 PM
Author Topic: Brodak CORSAIR started...  (Read 50908 times)
Offline Douglas Ames
« on: October 05, 2011, 06:25:13 PM »
I started with the crutch filler block custom cut for the width of a Saito .40 and realized the limited space left for a plastic clunk tank. I eliminated the bottom 1/8" side pcs. and used 1/2" tri stock instead to tie in the 1/4" top on the crutch, also used a couple pcs. of 1/2"x3/8" beam stock for braces and did away with the crutch filler aft of the 2nd bulkhead. The reason was to open up the fuel tank compt. to the max. I will be using a Sullivan 4 oz. round tank. More on that later.
I had to push the engine all the way up to the nose ring due to the ring thickness, I also wanted to get the prop away from the large cowl for better efficiency. The nose ring is 2 pcs. in the kit but came up a little short in dimension compared to the ply N/R doubler so I shimmed it 1/8". Lots of carving, sanding and contouring!!! You'll be removing over 50% of it so don't fret on weight...yet. I split the fuse up in quarters and contoured each quarter individually, that way I kept things symmetrical. Don't forget to block your corners or you'll see daylight.
The fuse sides were pre-assembled with ply doubler, stringers and 1/4" external doubler, then book-matched & checked for dimensions. This sets the accuracy of your fuse. I didn't use a jig, just a square and glass surface. I had to use a large clamp and some moisture to get the fuse glued together along with a precisely cut tail block behind the last former to straighten everything out before the aft fuse stringer s went in. I reccomend this - "triangulation", it's worth the minimal weight, if any. I moved the cockpit aft 1" for asthetics and give it a sleeker look. A custom canopy will be needed.
I decided to build the Bud Light "Super Corsair" of the 80's. A R-4360 powered Beast built from a ex-movie prop, an A-26 cowling and P-51 spinner. 8 feet was chopped from the wings but I have no intention to duplicate that! I'll just square up the tips for that look. Maybe a 3" span change? Spinner is a Hanger 9, aluminum 2 1/2", very nice quality!
Next up is a tank mount and plumbing, tail wheel and stab install.
« Last Edit: October 05, 2011, 06:48:57 PM by Douglas Ames »
AMA 656546
Re: Brodak CORSAIR started...
« Reply #1 on: October 05, 2011, 06:27:55 PM »
More pics...
AMA 656546
Offline afml
« Reply #2 on: October 05, 2011, 06:30:59 PM »
AWESOME JOB DOUGLAS!! y1
Keep the pics coming & "Tight Lines!" H^^
Wes
Wes Eakin
« Reply #3 on: October 05, 2011, 06:34:10 PM »
Here's the alignment block...Keeps your fuse from looking like a Banana.  ;D
« Last Edit: October 05, 2011, 06:51:50 PM by Douglas Ames »
AMA 656546
Offline Balsa Butcher
  • High Desert Flier
« Reply #4 on: October 05, 2011, 07:11:40 PM »
Impressive CLP**
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #5 on: October 05, 2011, 10:21:57 PM »
 Lookin' great so far Doug! I still have my doubts about the .40 choice though, but I guess we'll see.
 Check this site and scroll down to the "Cat's and Corsair's" five view line drawing section:
 http://www.taichiunlimiteddrawings.com/#Bearcats and Corsairs
 You will find some excellent reference for markings for your Bud Light version. Great reference for your models outlines and proportions too. These drawings are all very accurate, unlike a lot of stuff out there. There is info here on pretty much any Warbird air racer you can think of, past or present.
 Thanks and please keep the pics coming. y1
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #6 on: October 06, 2011, 01:34:57 AM »
The Corsair is 561 sq/in, I fly a 576 sq/in profile with a Saito 40 and it has plenty of power. The Brodak P-40 is 560 and we all know it does great with a Saito 40. The only unknown is the final weight of the Corsair, if he can keep it somewhat under 50 ounces he will be fine, 45 would be wonderful.
Offline Steve Fitton
« Reply #7 on: October 06, 2011, 08:11:35 AM »
If you made it E power you could reenact the real Super Corsair's harrowing final flight at the Phoenix Air Race S?P VD~
Sorry, I know that was naughty mw~
The corsair is one of my favorite planes, I'm going to enjoy watching this thread.  Its awesome that Brodak kitted this version!
« Reply #8 on: October 06, 2011, 11:40:45 AM »
I always loved the Bud Light Corsair. I have had a picture of it on my shop wall forever. I'll watch this build with interest.
« Reply #9 on: October 06, 2011, 03:20:41 PM »
Thanks for the ref's. That's exactly what I need.
AMA 656546
« Reply #10 on: October 06, 2011, 10:01:43 PM »
 Exactly what I'm thinking Bob, it's going to have to be built very light for it's size. Plus the design will have more drag than a comparable profile. I know and respect your experience with these designs, but I would be going for more power on the Corsair. Don't get me wrong, I love the Saito .40, but I don't expect much, if any, reserve power in this application. Just me maybe, I haven't seen the design in the flesh to get a total "feel" for it. Maybe it doesn't present as big as I'm imagining. I just always figure it's a lot easier to back off the power a little bit than to find more that just isn't there in the first place. It will be fun to see this one done. y1
« Reply #11 on: October 11, 2011, 07:53:58 PM »
Here's how I'm doing my Stab and Elevators. I put the hinge point (Du-Bro) in the center of the leading edge of the elevator with about a 1/32" gap. I also tapered the stab. spar and LE of the elev. from .375" to approx. .280", this keeps the surface angle constant otherwise it would wash out along it's span due to the taper in the elevator profile (different chord widths). I will also mount the stab with 1*+ incidence for good measure. Nothing spectacular but technically correct I think.
Need to continue sanding and blocking in the tail this week. It all fits good & straight so far.
AMA 656546
Offline Joe Gilbert
« Reply #12 on: October 11, 2011, 08:54:41 PM »
Doug that is outstanding keep up the good work.That engine will work very well did Bob do his magic already.
Joe Gilbert
« Reply #13 on: October 11, 2011, 10:27:05 PM »
 Very nice. Man I love watching this stuff. y1
Offline Rick Henry
« Reply #14 on: October 13, 2011, 11:25:39 AM »
Looking great Doug.  Makes me want to get started building mine all the more.  Keep posting pics please.
Rick Henry
« Reply #15 on: October 18, 2011, 07:28:59 PM »
Here's my vertical fin ready to install.
I trimmed 1/4" from the bottom fwd and aft edges, tapering up to -0- at the top then added 1/4" on the upper trailing edge, tapering down to -0-. This gives it a little more scale profile I think.
I glued everything as one and left the outboard surface flat. The inboard surface is aero-shaped with a 1/8" trailing edge. Pat J. suggested 3/8" offset so I sprayed the fin with glass cleaner (w/ ammonia) and curled it with some jury-rigging. I think this is a more efficient way of producing the required yaw than a cocked rudder (less drag maybe)...it also looks better  ::)
ps - A super trick to steam out dents is some glass cleaner (blue stuff) and your monocote iron. Evaporates quick.
AMA 656546
Offline Peter Nevai
    • C3EL
« Reply #16 on: October 19, 2011, 08:09:02 AM »
You understand that by doing the rudder this way people are going to constantly say "Hey did you know your rudder is warped?"  ;D
« Reply #17 on: October 19, 2011, 03:09:22 PM »
Yeah, I expect that, LOL.  ???
I'll be mounting it tonight 1/8" left of center to fit it on the narrow tail block. It will effectively have 3/8" offset overall with a nice fillet.
AMA 656546
Offline Gerald Schamp
« Reply #18 on: November 12, 2011, 09:27:32 PM »
Doug,
I have the orginal profile Corsair that Pat Jonston built for the Brodak kit. It has a Satio .40 in it and flies great. You won't have a problem with power for sure. Motor has one of Pat's carb mods on it, so there is just a NVA and a nylon screw to adjust air flow. Works great. Gerald Schamp
« Reply #19 on: November 13, 2011, 08:04:31 PM »
Gerald- That's good to know. Thanks! I'm trying hard not to build a balsa brick.
Currently finishing up the tail and tail gear. Roughed out the cockpit canopy (modified SIG teardrop) and have some idea where to go with that.
How was the wing build? Looks pretty straight forward.
AMA 656546
« Reply #20 on: November 13, 2011, 08:11:16 PM »
>>Looks pretty straight forward.<<
Well straight forward, but not straight.
« Reply #21 on: November 21, 2011, 09:41:32 AM »
I've got the tail roughed out, the verticle fin installed and added the req'd. small dorsal fin. Ready for fillets and final sanding/ covering.
Cockpit is nothing extrordinary, I had to add a 1/4" shim under the 1/8 pilot to get the right height and added a pc. of 1/16" for a seat back. Couldn't find a phone book that small for him. Canopy will be a trimmed down SIG 10" teardrop. I'll be using Al Rabe's methods for cockpit detail and canopy install (strips of glass/ resin).
Tail gear is DuBro's .40-.60 tailwheel. Simply modded by installing a brass sleeve/ epoxy instead of the steering arm. Perfect fit! It's dimensionaly the same as the plans and only weighs 11 gr.
AMA 656546
  • High Desert Flier
« Reply #22 on: November 21, 2011, 10:52:27 AM »
Really nice work, the sheeting looks like it could be challanging. Like the tailwheel also.  CLP**
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #23 on: November 21, 2011, 12:03:09 PM »
 Looking great Doug, please make sure to post some "how to" detail pics on the canopy install.
Offline Rick Henry
« Reply #24 on: February 03, 2012, 07:03:55 AM »
Hey Doug, How is the Corsair coming along?  Got any new pics?
Rick Henry
« Reply #25 on: February 03, 2012, 04:04:56 PM »
Doug,
You're doing a great job! Kudos!!
Corsair, my favorite warbird.
Couple of quick questions.
The cowling nose block, was that laser cut and how thick is it?
Elevator control horn, came with the kit? What's the distance between the bends?
Hope you don't mind.
Charles
« Reply #26 on: February 03, 2012, 09:43:06 PM »
I'm embarrassed to say progress is slow due to the holidays, OT at work and a scooter accident Christmas eve. (Indian Vespa clone - totaled). I'm starting the wing and getting ready to detail the cockpit.
Avio- the nose block is saw cut balsa, glued behind the nose ring (2 pc. laser cut) on the top. The external fuse doublers are 1/4". It all comes together when you start carving off chunks of balsa, then shaping and sanding a uniform profile. I did mine in quarters with a midwest plane and drum sander. You can put any powerplant you want in this kit - lots of room.
AMA 656546
« Reply #27 on: February 06, 2012, 03:01:38 PM »
Doug,
Thanks for that info.
I also asked about the narrow elevator control horn. Looks like it was made just for the Corsair? That came with the kit?
You're a ways away from paint and finish, but I have all the Budweiser graphics, also available in paint masks.
A-Jet
« Reply #28 on: March 04, 2012, 07:30:44 PM »
I bought an Acrylic paint set at Hobby Lobby and a brush asst. and went to town last week getting the cockpit finished. I think the little guy turned out good. Not a scale job, acceptable for stand-off scale. The helmet was the bomb in the early 70's - Easy Rider  8) Need to attach the canopy.
Think I need a landing for the fwd. edge of the canopy or just a bead of epoxy and then glass in the seam?
The rest of the edges overlap by about an 1/8".
AMA 656546
« Reply #29 on: March 04, 2012, 10:42:25 PM »
 Thanks for the update and the pics here Doug, things are looking great. I'm really interested to see how you pull of this canopy install.
« Reply #30 on: March 05, 2012, 08:04:47 AM »
The pilot looks great.   If you browse thru SSW's on the Rabe build, you will find  he lays a strip of fiber glass alog the joints of the canopy.  I also think Sparky has on his builds how he does his.   Of course it has been a while since Sparky has posted a build. D>K
« Reply #31 on: April 01, 2012, 11:31:35 PM »
 What's the latest Doug?
« Reply #32 on: April 07, 2012, 05:03:43 PM »
I'm building the wing (outbd). Hope to post some pics this weekend. Trying to get it up to sheeting so I can take it out of the jig.
AMA 656546
« Reply #33 on: April 07, 2012, 07:47:53 PM »
Gotta love the Easy Rider helmet.
« Reply #34 on: April 09, 2012, 07:49:49 PM »
Here I am plugging along on the outboard wing section. I didn't realize till after the fact that Brodak's wing jig is adjustable. The plans assume your going to use it so the ribs end up against the board when building 4 ea. sections. I went ahead and ordered a Tower Hbs. jig - big mistake. The rods are 5/16" solid steel (sag/ heavy) and the base is 2 pcs. of 1x2 particle bd. What a POS! I made it work by buying a couple F/G driveway markers (5/16") and got the tattooed punk at Lowe's to cut me a proper base from 1x6 pine.
With the rods 2" off the board you can build each wing half as one! Join the spars carefully first making sure they match the angles of the spars shown on the plans, enlarge your rib jig holes a little - Rib 4 is fragile! The L/G doublers will have to be drilled and mounted first for the jig rods. Also enlarge the cutout for the spar splices.
Flip your plans upside down and draw a ref. line 2" below the lower edge of the jig rod shown on the plans and then draw out some templates for the inbd. & outbd. ribs. (1/8" ply) Use these when you assemble the spar to the ribs. Obviously, you'll need mark the spar/ rib locations.
I did not butt splice the trailing edge but rather used a scarf joint on each side of Rib 4 - the break in the wing. This makes the transition smooth and strong.
This is just an alternative to the Brodak system, not implying it's any better but it's working out nicely so far.
« Last Edit: April 09, 2012, 09:36:22 PM by Douglas Ames »
AMA 656546
« Reply #35 on: April 09, 2012, 09:58:47 PM »
 Might be a stupid question, but why is there no inverted gull bend in the wing half that appears complete?
« Reply #36 on: April 10, 2012, 09:05:17 AM »
Looks like the wing is being built up side down. VD~
  • High Desert Flier
« Reply #37 on: April 10, 2012, 10:59:40 AM »
Look at the second picture a little closer, that's the outboard wing upside down - nice build, thanks for posting. 8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #38 on: April 10, 2012, 03:31:43 PM »
It's there, just not a whole lotta anhedral/ dihedral goin' on. I think Pat Johnston flattened out the gull wing for better performance.
AMA 656546
« Reply #39 on: April 10, 2012, 03:33:03 PM »
Yup, ...and right-side up when you flip it!  n~
AMA 656546
« Reply #40 on: April 10, 2012, 03:46:34 PM »
In talking with him, I think it was equal parts that he wanted the wing to be able to be built in one piece halves,, on an arrow shaft wing jig,, so thats all the dihedral you could have and still get the shafts to be within the ribs,,
« Reply #41 on: April 10, 2012, 06:12:33 PM »
 DOH! ;D Didn't even think of that, I see it now.
« Reply #42 on: April 17, 2012, 09:42:59 AM »
Some more progress...Shear webs installed on spar and T/E, weight box, and I sheeted the last bay for torsional strength. This ties in the end of the wing. By scarfing the Trailing edge sheeting on each side of Rib 4 and adding the 1/8" strip you can get a nice smooth transition on your aft edge. The chopped tip and sheeting is next, then I'll start the inbd. wing.
AMA 656546
« Reply #43 on: April 17, 2012, 01:14:58 PM »
Hi Douglas!
Coming together very, very nicely!  Very nice workmanship.  This will be a great looking model when finished. y1
BIG Bear
RNMM/AMM
« Reply #44 on: April 17, 2012, 10:12:34 PM »
 I'm diggin' this one. y1
 Thanks for the pics!
« Reply #45 on: June 03, 2012, 09:21:30 PM »
Well I finally finished the inbd. wing half and joined them tonight. There's really no reference to index the wing halves off of except the joiners and the plans. I carefully glued the joiners on opposite sides of each wing spar then cut the spar ends back to the exact center (marked). Laid the wing half over the plans with a square clamped and aligned with the plans - spar & centerline, then marked the L/E and T/E with another square. Had to shim the T/E but it all worked out, I thought it needed some type of joiner anyway.
I put the leadout guide inbd. of rib 12 and I'll be making some stubby wing tips soon and installing the center and L/E sheeting. The shear webs end a couple bays short due to leadout clearance.
AMA 656546
« Reply #46 on: June 05, 2012, 10:23:18 PM »
 Lookin' great! Is the fuse ready to go Doug?
« Reply #47 on: June 06, 2012, 03:53:13 PM »
The other thing is getting the LO's inside the wing and getting the LO guide at the vertical CG. Pat's got it under control!
Missed you guys at Regionals. Sinus infections aren't as much fun. H^^ Steve
« Reply #48 on: July 03, 2012, 08:09:22 PM »
I found out embarrassingly enough they do make long pushrods threaded for 4-40, duh!
Used a DuBro HD ball link and cut the pushrod accordingly. You'll need to slide the bellcrank aft slightly to line up with the rib cutouts and trim the doublers on the gear block ribs.
I added a rub strip for the leadouts because I terminated the L/O's up-side down on the bellcrank, oops. It all worked out.
Tips are solid blocks with a 1/4" center. I wanted a little weight on the tips to possibly help in the Okla. wind, dihedral and all that.
AMA 656546
« Reply #49 on: July 04, 2012, 08:06:11 AM »
Is that solid wire leadouts?    I quit using that for planes that did not require solid wire controls years ago.   Racing was the only place that I used them when I had to. H^^
