  • June 23, 2025, 06:03:07 AM
Author Topic: NEW FOAM a different way to build with foam inserts  (Read 7908 times)
Offline jose modesto
« on: May 02, 2012, 08:38:26 AM »
The objective is to find a faster way to build a SV22 wing. I have been molding balsa wing panels and building lost foam wings with ribs,this method produces perfect wing panels but time consuming. I was looking for a faster way.
I have been working with Bob Hunt on creating what i call foam inserts for vacuum bagging wing panels in a female mold.
I devised a way to cut a foam wing and keep a  foam perimeter that is used as a foam support for the 1/32" balsa skin.
With Bob Hunts vast experience in cutting foam the following system was created.
1) foam wing with out foam spars
2) center section removed
3) added 3/16"wood trailing edge
4)slpit in half
5)use half foam insert in composite balsa wood,glass,foam and epoxy.
Jose Modesto
Re: NEW FOAM a different way to build with foam inserts
« Reply #1 on: May 02, 2012, 08:42:44 AM »
Additional Photos
« Reply #2 on: May 02, 2012, 08:43:52 AM »
Additional photos
« Reply #3 on: May 02, 2012, 02:20:37 PM »
I really like what you get up to Jose - looks great
What do that panels weigh?
are you selling them yet?
« Reply #4 on: May 02, 2012, 03:35:14 PM »
Wynn. The panels range from 2.7 to 3oz in white primer 10.2 to 12 oz wings panels.
I was looking for a faster way to produce the prefinish SV22 wing panels without ribs,spars, or any interior support.
 Wynn at this time here in the US we are going through a rules cycle wen this is settled and we have clear rules i can them mobilize.
At this time im not selling any items.
The foam wing inserts make a good solid wing at resonable weights.
wyyn i will send private pm later.I have to go cook dinner.
Jose Modesto
« Reply #5 on: May 02, 2012, 04:02:20 PM »
look forward it Jose - enjoy your dinner..
« Reply #6 on: May 02, 2012, 08:22:46 PM »
Good stuff Jose,
When I last talked to Bob he was explaining this process to me. He said that it is so simple that there was no need to purchase these shells from someone, anyone could do them by theirself. He said that he was working on an article that explains how to do it and for the most part it is pretty simple and as usual, ingenious. He explained the process to me and I look forward to trying it for myself.
Good job Jose.
Derek
p.s. nice try!
« Reply #7 on: May 02, 2012, 10:11:41 PM »
"D" take a look at the top of this section i brought up a previous thread on incorporating composite construction.The system that Bob described to you is the system that i started with in 2002. i learned this from a video by aerospace composites.the system shown was for glider foam wings vacuumed bagged in a Mylar folder. D this is the system that Bob described to you.
why did i stop using this system first the leading edge needs sanding as the Mylar will not create a clean leading edge and second
 I WANTED THE TIPS included. With the Mylar folder the tips have to be made separately.
why did i go into molding as appose to traditional building. I have developed a real allergy to balsa dust and CA, traditional building was making me sick to the point that my health was in danger if i kept building in the traditional way. since all molding is done with 1/32"balsa i could purchase sheets glued by others that did not require sanding by me.
This method allowed me to continue in the sport that i have participated in for 46 years.
The two wings systems that i posted are nothing like what Bob described to you.
initially i eliminated 95% percent of balsa in my models i will post two models built with fiberglass cloth,.5 CFM and epoxy.
Bob has the same challenge with the leading edge requiring some sanding while the shells molded in female molds you get the tips and PERFECT LEADING EDGE which was my goal. I have to thank Windy U for his pioneering work on composite vaccum bagged wings panels, Windy's composite wing videos 1,2 and 3 have formed the foundation for my composite wings.
Jose Modesto
« Reply #8 on: May 02, 2012, 10:33:30 PM »
D some photos for you of models that used the Mylar folders system 2003
wen bob showed me his system i said Bob the leading edge does Not come out perfect his comment. Don't let the perfect be the enemy of the good. or words to that affect.( I still use the Mylar folder to apply the glass to the foam and wood flaps on my models.)
Bob said so what that you have to sand the leading edge,my comment was that i wanted to have a perfect panel thus his comment.
that comment has changed my views on continuing the quest for perfection were 98% is good enough.
photo #1,2 and 4 Big Jim El-Jay 46 the only wood in model is 1/4" wing leading,trailing edge,fin,wing tips and rudder.
photo # 3 my half profile with inverted engine. these components were given to Neal Beekman who built the model all flying surfaces are foam with glass and epoxy in a Mylar folder.
photo #5 foam wing with yellow taffeta for color again no wood.
All foam components were cut By John Duncan.
Jose Modesto
« Last Edit: May 04, 2012, 04:50:17 PM by jose modesto »
« Reply #9 on: May 03, 2012, 04:48:17 AM »
Jose,
I have the same problem when I paint, my lungs hurt for a few days after. I guess we should both look into some high quality dust masks.
You are correct, the method that Bob told me about still has to have the tips added later. Yours is very nice, cool to see the tip included. I remember these pictures from a few months ago. As long as they have to be "finished" by the contestant I have no real problem with them. If they come painted or in "shiny white primer" I would have a problem with that...
Again, nice work.
Derek
« Reply #10 on: May 03, 2012, 06:01:54 AM »
D as I stated. the paint in the mold are for me and my friends that can come over and apply the paint and want to compete in JSO at the Nat's..
As you well know there are NO appearance points in local contest in many PAMPA districts,specially in the east.
For PAMPA classes the paint in the mold is acceptable, as you can compete with a model built and painted by others.
There is only one contest a year were the painted in the mold models are not allowed JSO at the Nat's.
A couple of photos of my first foam insert wing. I used Kevlar 2.3oz/SY material with .5 glass cloth and 2 layers of .5 CFM inside with a 3/16" foam. Windy forgot to mention that you cant sand Kevlar thus this wing was never used for a model. 8 years later i repeated the same error and made the most perfect Kevlar wing panels and then had to sand the seam leading edge,again beautiful useless wing panels. I'm getting old.
Jose Modesto
« Reply #11 on: May 03, 2012, 06:14:40 AM »
Jose Modesto
I am not aguing that you cant use them in most, if not all contests, on the east coast. I was referring to the BOM at the Nats. No need to go down that road again...
Hey at least those kevlar wings are bulletproof.  ;D
D
« Reply #12 on: May 03, 2012, 06:16:03 AM »
BTW, those two wing panels that you are holding are very nice!!!
Derek
« Reply #13 on: May 03, 2012, 06:42:13 AM »
D that is funny.Bullet proof LOL. that all they are good for
So guys don't use Kevlar on the exterior unless less you are in a gun fight and need to hide behind your wing panels.
The foam panels were real easy to do with the Mylar folder, all you need are the foam cradles and some weights,just like sheeting a foam wing.
I went further and painted the Mylar then laid the .5 glass cloth with epoxy, balsa 1/32"sheet,epoxy and bagged that unit on the uncored foam wing and got a perfectly finished wing panel.The draw back was that i still needed to add the leading edge. Since i wanted a complete wing panel I abandoned this method for the Female molds
The female molds have allowed me to build every type of wing from foam,built up,solid surface built up,Dixon Kept foam my last one is an  ribless Ibeam
To date the combination of Bob Hunts lost foam system with the Molded Shell have created the most versatile wing building system created to date.
Jose Modesto
« Last Edit: May 03, 2012, 07:50:00 AM by jose modesto »
Offline bob branch
« Reply #14 on: May 07, 2012, 07:24:28 PM »
Jose
Actually there is a way to use kevlar so you can sand the surface. Just add a layer of light weight glass cloth over it. You'd need to vacuum bag it otherwise there is fair chance of the glass lifting a bit and creating the ugglies due to the texture differences in the two cloths .... Don't ask about that. .... But I have used this method in boat construction when doing a composite one off hull on male molds. If you want to use carbon that is doable too, I have used that type of layup with carbon canoes where we use a kevlar blanket under the exterior carbon ones to stop cracks from propagating in the carbon with impacts (even high quality canoes with high quality paddlers have occasional impacts). Don't know how the weights would come out compared to what you are doing as I always worked with heavier cloth in the carbon and kevlar than you would be. At any rate, the glass makes a nice smooth sanding veil.
BTW, I too thought I had developed an allergy to balsa dust. Did some allergy testing and was not the case but my lungs would become a wreck. Turned out it was the shape of balsa sanding dust fibers. Look at some under magnification. The look just like snowflake crystals... except when they get warm the don't melt, they are still sharp with fibers going in all directions. Not the nice little round stuff you think it is. When that gets in the lungs ouch... and it has trouble getting out because it embeds in the soft tissue lining and will not flow out with the mucous as most foreign debries does. I sand in an OSHA vapor mask now. End of issue. And I can use the same mask for painting, except for 2 part poly, then need forced air supply to be safe... so I gave that up. Now in electric it doesn't matter. I don't need the fuel proofing.
Be careful with the epoxies and epoxy dust. It can become an extreme allergen. Many 100% composite homebuilt aircraft projects out there partly finished by the unwary. I only sand the stuff with long sleeves and OSHA mask. BTW, if someone refuses to invest in an actual OSHA mask (the old filters that are out of date for solvents BTW are still good for particles like balsa so I use those for balsa sanding) there is a whole nother area of particulate mask protection available. Some medical surgical masks have multiple layers to filter out very fine particulates like bacteria and virus. They can also be fit more accurately to the face than most of the stuff you get at a hardware. Medical or dental supply houses should have them. The ones I use are by 3M and are molded with one elastic around the neck. I use this type because I work with surgical microscopes and surgical lighting on a head frame. But they are available in the rectangular two ear elastic versions as well. Buy them by the box, they are much cheaper. Don't even know if they are available separately. Certainly would not be from a medical or dental supply. We'd want tracking of the batch numbers and sterility.
bob branch
« Reply #15 on: May 17, 2012, 12:29:43 AM »
A double filter face mask is essential.
When I sand I wear a mask...... Stuff the idea of getting balsa/primer/carbon/paint dust in my lungs
I even wear nitrate gloves becsaue I hate the feeling of CA on my fingers..............
I like to build in a hospital environment !
Offline Tim Stagg
« Reply #16 on: July 03, 2012, 11:07:41 AM »
Jose,
Send me a personal message with your current email address, for some reason every time I try to email you it bounces back. Would like to talk to you about maybe coming up to see your process. I would like learn more.
tstagg@goeaston.net
Tim
Tim Stagg
Offline Jeff Traxler
  • T-Bone
« Reply #17 on: July 04, 2012, 12:51:35 PM »
Jose,
    I like this idea.Unfortunately it is identicle to the process I discussed with Mr. Hunt last fall.He even cut me a core to use to make the female molds from.We even talked about little things like shell thickness,shell shape,cloth types,weights ect.I even spoke to you at the team trials last fall about this very subject.He did'nt seem to think it would work but now that he thought of it it is instantly"Sliced Bread".I don't have a problem sharing my ideas with anyone BUT it burns my ass when people tell me "That won't work" and then claim to be the genius that thought of it.This is not patented so have at it but when you take credit send some to the people that deserve it.Jeff
« Reply #18 on: July 08, 2012, 05:29:02 PM »
All I can say is welcome back Bob!!!!
« Reply #19 on: July 08, 2012, 05:52:20 PM »
Thanks, Wynn...
how about an update on the twin electric...
was waiting in anticipation to see that finihsed - then you left (for good reason)
« Reply #20 on: July 08, 2012, 07:11:39 PM »
Welcome back Bob also!  H^^
I wanna know why Osama no vsc fly.
  • T-Bone
« Reply #21 on: July 08, 2012, 11:14:51 PM »
Bob,
     It just struck me funny that when I ordered that core from you last fall I spelled out all the things I planned to do with it.Very similar to this thread.You did'nt seam to think it would work but you cut me the core anyway.You are a bit errogant,seams you would have mentioned the 5 year plan????Everyone knows you were born into modeling so you SHOULD be good at the things you do.That's not the issue.If you choose no longer to disclose your overflowing abundance of information I just hope C/L stunt will survive without the best way to do everything
        Just Sayin' H^^ H^^ H^^
Offline Allan Perret
  • Proverbs
« Reply #22 on: July 09, 2012, 05:21:22 AM »
Hey Bob:
Dont let this guy get you down, like what happened about a year ago.
In the words of Col. Jessup:
"We need you here, we want you here!"
or somthin like that
« Last Edit: July 09, 2012, 06:47:20 AM by Allan Perret »
Allan Perret
AMA 302406
Slidell, Louisiana
steven yampolsky
« Reply #23 on: July 09, 2012, 06:40:05 AM »
I share information as well or better than anyone in this hobby/sport. Sometimes I am taken to task for giving out too much information.
I say, 6 columns in the AMA Mag is not enough! Your engineering and finishing solutions are interesting and educational. I wish you had your video series back on the air. Isn't it time to update them with new techniques and lessons learned after 15-20 years since the initial creation of the videos? If you decide to do it, I'll be the first one signed up!!!
I find that the style of your video's are very similar to the high quality production style of modern woodworking shows like the Woodsmith TV show.
  • Proverbs
« Reply #24 on: July 09, 2012, 06:50:05 AM »
I would be "All IN" for some new videos.
But I know that takes lots of time..
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #25 on: July 09, 2012, 07:51:30 AM »
Come on guys, I am glad to see Bobby is posting again.   I know him and can remember the first time I met him.  Bobby, remember the flags for the tall masted schooner in Lake Charles LA?   I too have been noted as being stuck up myself at times.   I used to think people would'nt like to talk to a kid fresh off the farm and I held back.   Most of the guys/gals I ran with got me out of that mode in away.   But, I have learned that if you don't  talk to people, they may not talk to you.   I am thankful I have met so many people in this great modeling realm.  With my memory, it has to be refreshed once in a while.   It's like the old electronic switching machines for the phone company, it goes into phase mode.
Now Bobby, how is the twin coming?   Also not to jinx you, but, would love to see you holding the Walker Cup again as well as the Open National Champ Title.   H^^ H^^
« Reply #26 on: July 09, 2012, 11:54:17 AM »
I was thinking foam wings for The Flamingo. There are 4 and 2 rudders.
Open bay wings are extra work.
Bob's articles are great!  Bob's articles are the only thing I look for in that Mag.
Bob tells it like it is, doesn't misrepresent, and gives all the information up.
Do you find that often?  H^^
Keep up the good work Bob. You have followers.
Charles
steven yampolsky
« Reply #27 on: July 09, 2012, 01:57:32 PM »
Steve: I've been toying with the idea of getting a Mac 'puter and Final Cut Pro Studio and getting back to video production. Find me another 12 hours in the day and I just might be convinced to do it... :)
Sleep is overrated  LL~ LL~ LL~
« Reply #28 on: July 09, 2012, 02:08:00 PM »
I always say, "I can sleep next month."  n~
Offline BUD WIEDER
« Reply #29 on: July 09, 2012, 08:16:10 PM »
JEFF, I REALLY DON'T KNOW YOU AND I'M SURE YOU DON'T KNOW ME, BUT.........  I HAVE NEVER KNOWN BOB HUNT TO TAKE CREDIT FOR ANYTHING THAT WASN'T HIS IDEA.  HE ALWAYS GOES OUT OF HIS WAY TO GIVE CREDIT TO OTHER PEOPLE FOR THEIR IDEAS.  HE IS THE MOST OPEN AND SHARING PERSON I HAVE EVER KNOWN IN OUR HOBBY AND WE ARE LUCKY TO HAVE HIM AND HIS GREAT TALENT.  BUD
Offline Dick Pacini
« Reply #30 on: July 09, 2012, 10:00:50 PM »
I first met Bob Hunt at the 1973 NATS.  It was my first time entering the NATS and Bob's first time entering in PA.  His Genesis was absolutely beautiful and the lightest airplane I ever held.  We psyched each other up to qualify and we both made it.  Of course, Bob was outstanding and took 9th place in the finals, while I landed in last place at 18th.
I was very impressed with Bob's foam wing.  After returning home, I ordered my wing design from him and it was absolutely a work of art.  I used that wing in the plane I built for the 1974 and 1975 NATS.  I tanked both times, but enjoyed the experience.  Here, 38 years later, I still have that airplane and that wing.
Anyway, I left modeling for 36 or so years.  A while back, I called Bob and re-introduced myself.  He remembered me and we talked for a couple of hours like old friends.  He is still as down to earth as he was in 1973 and still as willing to help anybody build a better airplane.  His talents are beyond reproach and I believe he is one of the true masters of PA in every phase of it.  I have spoken to him a few more times since then.  He is always available to talk and provide information.
I am really glad to see him posting again.  I hope he stays to enrich the board.
AMA 62221
  • T-Bone
« Reply #31 on: July 10, 2012, 12:30:04 AM »
Hi Bud,
      So nice of you to join Stunthanger just so you could rip me and sing the praises!!!Welcome aboard.Bob just might be right,this is an unimaginable coincidence.See ya's in a couple days y1
« Reply #32 on: July 10, 2012, 01:26:24 AM »
Jeff : You stated your opinion ,others have disagreed - its time to move on.
I highly doubt Buddy joined just to get into you - He's not that sort of guy, like Bob - Buddy is class all day.
2 bad calls from 2.. Nice work.
  • T-Bone
« Reply #33 on: July 10, 2012, 11:54:30 AM »
PJ,
    It was his first post!!!
  Lets imagine you telling someone about the vortex generators before you said anything to anyone else and they did'nt happen to mention the fact they were working on somthing VERY similar.The idea came up in a forum and was "The next big thing".Would you say something???Even if you knew the wrath of god(and apparently his disciples)was going to be in store for you.Would you be a man and say something????Even if you had been involved in the hobby for a much shorter time than the person you confided in??????The funny thing is I have been a FAA liscensed aircraft mechanic and involved with the EAA for 35 years and I have followed full size composit aircraft construction since some fella named Rutan started with foam and fiberglass construction on the Veri-EZ.Where I come from CLASS starts with standing up and being a man,Standing for what you believe in even though the wrath was comin'.At least Mr. Hunt finally admitted we had a conversation.I won't kiss anyones a$$ just to fit in.That's just CLASSLESS
« Reply #34 on: July 10, 2012, 12:59:40 PM »
Bob,
Are your foam wings cut by CNC?
DXF files?
Charles
Offline Tom Niebuhr
« Reply #35 on: July 10, 2012, 01:16:21 PM »
Jeff,
Buddy Wieder has been a member of the Stunt Hanger forum for quite some time. He reads and mostly has no comments. He a superb flyer and is a very giving person. It might be his first post, but don’t start criticizing someone that you don’t know! Buddy is not a newbee. I first met him about 1959.
I have found over the years that I have created many methods and tools to help my own building and found out that others have also developed the similar same methods. Necessity is the mother of invention. They have not stolen my ideas! People have parallel thoughts!
Bob Hunt has been helping people and shares his developments with the Whole World. He NEVER fails to give credit to other people. We are in a hobby that thankfully shares, and developes things that are built upon things others accomplish.
Bob is a past National Champion and World Champion and unselfishly helps everyone.  To question Bob’s character is an INSULT to all of us in the hobby.  He would NEVER steal another’s idea!
I have known Bob for over forty years, believe me his character is impeccable!
In addition I am a licensed Airframe and Powerplant  mechanic with an engineering degree.  I have built two homebuilt airplanes.  I also have flown full size aerobatics, and have Single and Multi Engine, Instrument and Instructors ratings.  My college roommate worked with Burt Rutan at Edwards AFB  when Burt was still in the Air Force and had just built the Vari Viggen. This was during F-15 flight tests. I met Burt at Mcdonnell Aircraft when he visited us with his Vari Viggen, long before the Vari EZ series. I was also in engineering on the F-15 project.
And… you know what…. This has absolutely nothing to do with this conversation and should impress No One! The stunt fraternity is full of similar experienced people in aviation: pilots; mechanics; and enthusiasts.
I suggest that you stop throwing darts at people that you don’t know!
« Last Edit: July 10, 2012, 01:43:11 PM by Tom Niebuhr »
AMA 7544
  • T-Bone
« Reply #36 on: July 10, 2012, 02:13:28 PM »
To whom it may concern,
     I called Bob after reading his last post in this thread.We talked for a bit and now we both realize how a little misunderstanding can be blown out of context.The one thing that I never wanted to do was make it sound like Bob has'nt done an enourmous amount for the hobby and everyone/everything in it.I apologized for making it sound that way and now things will be better between us.I won't apoligize for standing up for what I believe in but I do realize a simple phone call first may have been the best way to handle this misunderstanding instead of posting first.I am guilty as charged for that and I sincerely apologized to Bob and I send that to all who may have been offended.If there are still people out there that wanna rip me have at it,This is still America!!!!As far as I am concerned this misunderstanding is understood,All good,See ya's at the Nats,
        Jeff "T-Bone" Traxler
Offline Mike Keville
« Reply #37 on: July 10, 2012, 03:34:02 PM »
Glad to see that's been settled amicably.  Bob Hunt is among the most honest and ethical folks in the hobby.
« Reply #38 on: July 11, 2012, 06:08:33 AM »
" PJ,
  Lets imagine you telling someone about the vortex generators before you said anything to anyone else "
I disavow any knowledge of such devices..........
« Reply #39 on: July 11, 2012, 02:45:04 PM »
Jose,
OK, with all this now settled, you produce two shells for the wing what is the structure needed to secure them to the rest of the plane and how are the controls installed?
What is the advantage over simply making skins from balsa/glass/epoxy using the foam cradles and core as forms?
Best,      DennisT
« Reply #40 on: July 14, 2012, 12:46:28 PM »
Hi all:
Jeff's absolutely correct; a simple phone call from either of us to the other would have quickly solved this monumental misunderstanding. We are now good and I wish that you all will simply forget this ever happened and hold no ill will against Jeff. We did a virtual hug over the phone and will do that in actuality at the Nats as well.
All this stemmed from something that I had promised someone else that I would not disclose that was identical to an original idea that Jeff had and that he had discussed with me. I couldn't tell Jeff that, because it would cause me to break a confidence that I had with the third person. Once Jeff heard that, he knew that I had not done anything improper.  That third person finally announced the idea on the forum (which he's been working on for the past few years...) and Jeff thought that I had told that person about his (Jeff's) idea. It was as Tom Niebuhr suggested, a classic case of parallel development.
This should serve as a lesson for all of us on these forums. We need to speak with each other personally whenever something like this arises. Lots of hurt feelings and typing could be avoided.
Jeff and I will be practicing together at the Nats. Come join us!  #^
Bob Hunt
Bob you truly are a Gentleman.
I don't know Mr Traxler, but in your shoes I would be trying to find him and break his nose...You are, my friend a truly unique individual and one of the finest gentlemen I've had the pleasure to know.
« Reply #41 on: July 24, 2012, 11:07:54 AM »
Bob,
Jeff is also a very accomplished guitar BUILDER.  he makes some fine instruments, both electric and acoustic.  We swap supplies, techniques, and other guitar stuff from time to time.  (Now, if I could just get him to throw that #*(*$@#*$$# slide away.) LL~ LL~
