Building Tips and technical articles. => Building techniques => Topic started by: James Mills on February 28, 2008, 09:48:47 PM
I've seen this mentioned in other finishing threads, what exactly is a blocking coat? Is it synonymous with the primer coat or is it something else?
James
James
It is a rough color coat, either silver, (or my favorite a very light gray) used to cover all the variations in finish before you spray your final color coats. Makes coverage easier and helps to point out last minute flaws.
Windy uses the silver as a blocking coat and fine primer (or at least he use to!) after his filling is finished since one you sand it, ANY flaw will pop out at you!
If you read the fine print on Randolph paint (source of Brodak).
"Yellow and red colours are transparent. They must ONLY be used over WHITE".
That is very true. Windy use to sell yellow and white pigment to add to those color dope.
I like to add just a touch of gray or black to make the blocking coat a slightly off white which covers easier.
Do you try for "complete" coverage with the white before yellow (this might explain part of the problem I had on my Hallmark)?
James
I'm afraid I have to differ with the "yellow only over white" concept. It depends on the type of yellow being used. I just finished the painting on my new twin boom Ephesian with yellow over powder blue primer to give me the tint I wanted and it is a great yellow colorwith a slight green tine. In the sun it will change color from under cloudy conditions. By varying the under coat color you can really play around with different results of tints, quite similar to whether to use gold or silver under a candy apple finish. That's the fun of painting, using all the variables to experiment! and yes, yellow is translucient, as is red, and, "gasp", even some blacks.
Will
Will
When it comes to dope, it seems they are ALL translucent to some degree....
That's true, and that's also why I no longer use dope for color. I've seen too many dope jobs of my buddy's turn "strange" after curing! I'll mention no suppliers, but it can happen to many of them I suppose.
The development of affordable two-part clear has freed us to use many sources of color and I love it.
Blessin's
Will
