  • July 04, 2025, 03:29:02 AM
Author Topic: Black APC prop  (Read 1667 times)
Offline Dave Moritz
Black APC prop
« on: January 11, 2020, 03:34:51 PM »
Folks;
Here is a shot of an 8x4 APC prop given the Rit Dye treatment. It took several hours in the juice per the directions on the packet, but am happy with the outcome. Might have read about the technique on this board, but not sure. Whoever suggested it, good kudos to ya!
Dave Mo....
Offline pmackenzie
  • Pat MacKenzie
Re: Black APC prop
« Reply #1 on: January 11, 2020, 03:43:18 PM »
When I did it I put the pot on "simmer". Hot, vapors coming off but no boiling.
(Black works better than red :) )
MAAC 8177
Online Dave Hull
Re: Black APC prop
« Reply #2 on: January 12, 2020, 01:13:35 AM »
A buddy of mine showed up with a really cool prop once. It had wood laminations just like a full scale barnstormer prop from back in the day. Then he told me to look closer. It was a scimitar APC that he had dolled up with woodgrain and glue lines. It was pretty slick. I can't recall if he dyed it wood tone before starting on the wood grain painting or not. It definitely belonged on a scaley plane....
The Divot
Offline dennis lipsett
Re: Black APC prop
« Reply #3 on: January 12, 2020, 07:58:12 AM »
APC does make black props check some of the RC providers to see what is available. You just might be surprised.
Offline bob whitney
Re: Black APC prop
« Reply #4 on: January 12, 2020, 08:25:37 AM »
the APC black props are carbon fiber mostly in RC pylon sizes. they work good in u/c Quickie Rat
rad racer
Re: Black APC prop
« Reply #5 on: January 12, 2020, 11:39:33 AM »
Safety feature, paint the tips white or yellow. D>K
Offline Dave Moritz
Re: Black APC prop
« Reply #6 on: January 12, 2020, 05:39:41 PM »
Right on, good doc!
Dave...
Offline pmackenzie
  • Pat MacKenzie
Re: Black APC prop
« Reply #7 on: January 12, 2020, 05:54:52 PM »
I don't think it makes much difference, if you follow safe practices and never reach around a spinning prop.
Get behind it before doing anything.
I see guys taching from the front and reaching back to adjust the needle - scary dangerous on two fronts.
MAAC 8177
Offline Perry Rose
Re: Black APC prop
« Reply #8 on: January 13, 2020, 06:52:21 AM »
I've dyed lots of APC props using just Rit in hot water and 5 minutes or less soak time.
