  • June 16, 2025, 02:33:17 AM
Author Topic: Cloth hinges.  (Read 1894 times)
Offline Perry Rose
Cloth hinges.
« on: December 07, 2022, 02:11:38 PM »
I need some material for the hinges what is the best to use?
Offline Dan Berry
Re: Cloth hinges.
« Reply #1 on: December 07, 2022, 06:14:24 PM »
I used SIG Coverall or Koverall on this.
Attached with nitrate dope.
I cut it on a diagonal bias.
Offline Perry Rose
Re: Cloth hinges.
« Reply #2 on: December 08, 2022, 05:15:26 AM »
Thanks guys, I'm off to the fabric store.
Offline Bruce Shipp
Re: Cloth hinges.
« Reply #3 on: December 10, 2022, 11:35:07 AM »
Dacron or taffeta from fabric store.  May be the same stuff.
Here's a hint.  Take a piece a foot or so square.  Iron it smooth.  Using a light pencil and straight edge, draw out a grid using whatever size hinges you want; 1/2" by 1" or whatever.
Next, take a striping brush and run a narrow line of dope over the pencil lines.  Let dry and cut on a cutting board using a straight edge and sharp razor. I like the double edged blades broken in half.  They seem to work well on the fabric. A number 11 blade tends to snag the threads. Or better use a fabric cutting wheel.
You now have nice uniform hinges and the edges wont fray when you handle them.
