Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 06, 2025, 01:38:08 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Building Tips and technical articles.
Building techniques
(Moderator:
RandySmith
Best gap filler?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Best gap filler? (Read 1934 times)
Dennis Toth
2020 supporter
Trade Count:
0
Admiral
Best gap filler?
on:
August 13, 2012, 12:40:02 PM »
Guys,
Am getting to the point of seating the wing in the fuse and there are some small gaps to fill. In the past I would use some small scraps of wood and just glue it in. Is there anything stronger and easier?
Best, DennisT
Logged
Gene O'Keefe
2014 Supporters
Trade Count:
0
Captain
Re: Best gap filler?
Reply #1 on:
August 13, 2012, 01:44:16 PM »
If you do have small gaps to fill, small pieces of balsa will work. Glue them in with epoxy for strength. Be sure to use a Robart (or home made) incidence gauge to level wing with thrust line. After that I would use Super Fil as fillet material. JMHO
Geno
Logged
Gene O'Keefe
AMA 28386
Will Hinton
25 supporter
Trade Count:
0
Admiral
Reply #2 on:
August 13, 2012, 02:15:41 PM »
I certainly agree - nothing works better than balsa glued in place.
Logged
John 5:24
www.fcmodelers.com
Allan Perret
2017
Trade Count:
0
Admiral
Proverbs
Reply #3 on:
August 14, 2012, 06:22:08 AM »
I use strips of 1/64 ply.
Logged
Allan Perret
AMA 302406
Slidell, Louisiana
Dave_Trible
24 supporter
Trade Count:
0
Admiral
Reply #4 on:
August 14, 2012, 05:19:30 PM »
Just recently stumbled across a new product (new to me anyway) made by J B Weld. Called Kwik Wood. Its a putty you mix with your fingers like chewing gum.You then work it anywhere. It would remind you of Epoxolite-only thicker. Ready to sand in 30 minutes. Its tough and not too heavy for smaller jobs. Get it at the Home Depot.
Logged
Dennis Toth
2020 supporter
Trade Count:
0
Admiral
Reply #5 on:
August 16, 2012, 11:26:05 AM »
Guys,
David's comment made me think, has anyone used regular "JB Weld" as a gap filler? Seems for internal areas this should be very strong and vibration resistant.
Best, DennisT
Logged
PJ Rowland
AUS - 29541 AMA - 809970
Trade Count:
0
Admiral
Melbourne - AUSTRALIA
Reply #6 on:
August 18, 2012, 03:54:13 AM »
Seams around wing to fuse are certainly places where you want decent strength - and a little flex.
In the past i've used epoxy with chopped carbon fiber. You can alter the consistency with how much carbon you add. Can be thin or quite thick and paste like.
Just make sure you wipe off any excess to avoid sanding it too much - it will sand but not as well as superfil. Depending on how much gap you have, small gaps superfil is perfect. If you have anything more than a 1/16 gap I'd try to fill it with Balsa first or the epoxy.
Logged
Clint Ormosen
2019 supporter
Trade Count:
0
Admiral
Reply #7 on:
August 18, 2012, 10:22:06 PM »
Balsa makes the best filler around wing joints. I use 1/4" wide strips of the needed thickness wedged into the gap. Then dump in the epoxy. A heat gun will make the epoxy run like water to really get into the small cracks and make the joint really solid. After that use whatever fillet material you like. I use Epoxolite.
Logged
FLOYD CARTER
24 supporter
Trade Count:
0
Admiral
Reply #8 on:
August 19, 2012, 03:25:49 PM »
I get best results with 15 min. epoxy with lots of "micro balloons" mixed in. Add a bit of acetone for smooth application.
Logged
AMA #796 SAM #188 LSF #020
Print
Pages: [
1
Go Up
« previous
next »
gaps
stunthanger.com
Building techniques
(Moderator:
RandySmith
Best gap filler?
Jump to:
=> Building techniques
