  • July 13, 2025, 02:49:43 AM
Author Topic: Bending CF rod for landing gear  (Read 2389 times)
« on: September 10, 2014, 08:32:59 AM »
Guys,
In an effort to keep weight down I have been looking into using 5/64" solid carbon fiber rod material for landing gear. The ship is a 25 size and will weigh in at around 34 oz. It will be tricycle gear and I am working hard to save weight were I can and the gear has a good shot. I have the CF rod and thought I could heat it and shape it but when I tried heating with a regular heat gun it laughed at it.
Has anyone tried this? How much heat and from what source?
Best,        DennisT
Re: Bending CF rod for landing gear
« Reply #1 on: September 10, 2014, 09:53:10 AM »
Guys,
Best,        DennisT
Dennis,
You can save weight by eliminating that third wheel.  n~
Offline Lauri Malila
« Reply #2 on: September 10, 2014, 10:33:16 AM »
Sorry, that is not possible. The fibers will delaminate as you bend the rod. It will first fail on compression side.
You can only very slightly heat & twist the pultruded rods, like re-pitching props but even then you must be very carefull. L
« Reply #3 on: September 10, 2014, 10:39:54 AM »
Laurie is right. You can get it to move a bit (as when carbon props are re-pitched) but not the kind of bend you are talking about. It will just delaminate and fracture. I've made carbon gear, but you have to lay it up that way.
Tags: gear
