  • August 03, 2025, 04:03:06 AM
Author Topic: Bellcrank mod  (Read 2193 times)
Offline Tim Chenevert
Bellcrank mod
« on: March 04, 2018, 07:26:59 PM »
I need a push rod hole 7/16” from the pivot point on a bellcrank. Can the rest of the push rod arm be cut away to save space? This is a nylon Brodak bellcrank. The bellcrank needs to move more towards the centerline. Thanks, Tim
Baton Rouge Bi-Liners
AMA 179681
Re: Bellcrank mod
« Reply #1 on: March 04, 2018, 07:54:18 PM »
I just did that to a Brodak Nylon that the pushrod arm was too long.   Make sure you don't cut too close to the push rod. D>K
Re: Bellcrank mod
« Reply #2 on: March 04, 2018, 08:08:33 PM »
Thanks John. Tim
« Last Edit: March 05, 2018, 03:32:02 AM by Tim Chenevert »
AMA 179681
Offline Dane Martin
  • heli pilot BHOR
Re: Bellcrank mod
« Reply #3 on: March 05, 2018, 04:29:09 PM »
Agreed. Leave what you can, but no problems cutting away what's unused.
Re: Bellcrank mod
« Reply #4 on: March 05, 2018, 07:31:01 PM »
Done deal and it works great! Thanks, Tim
AMA 179681
