  • August 02, 2025, 03:52:49 PM
Author Topic: Light profile bolt on gear - Who makes/sells them?  (Read 1777 times)
« on: May 19, 2020, 01:36:29 PM »
Working on the S-1 Ringmaster rebuild I'm looking at replacing the wire gear with maybe a carbon fiber bolt on or Aluminum. Who makes/sells these components?
Best,     DennisT
Online Jim Hoffman
Re: Light profile bolt on gear - Who makes/sells them?
« Reply #1 on: May 19, 2020, 04:38:54 PM »
Steve Wilk of Eliminator Props makes CF landing gear exactly what you need
Offline Jim Carter
« Reply #2 on: May 19, 2020, 04:55:43 PM »
Hi Dennis!  How about something like these?  I use them on Ringmasters and such and slightly longer ones for planes mike my modified Big Tigers.  They're plenty strong enough!  I use the Brodak aluminum Gear Blanks, BG-1964 or BG-1965 with Dubro 1/8" or 3/16" axles as needed/preferred.  I'd like to ask $25 plus shipping or you can easily do 'em your self and save the $5.00  ;) :) :)
Jim Carter
« Reply #3 on: May 19, 2020, 05:40:59 PM »
I tend to make my own.
Offline BYU
« Reply #4 on: May 26, 2020, 08:03:53 PM »
How long are those  Eliminator Prop landing struts? It says they are for a Primary Force so I'm thinking they are too long for a Ringmaster.
Motorman 8)
Try moving them up the fuselage side (fit higher up)
Or pick up some 1/2 x 1/8 aluminum strip from a hardware store and bend to shape.
(Similar to the original Primary Force ARF gear).
