  • August 01, 2025, 10:05:49 PM
Author Topic: Bellcrank bushing leadouts- step by step  (Read 5318 times)
Offline Bob Johnson
  • Lone Eagle Stunt Flyers -Have stooge. will travel.
« on: December 06, 2006, 09:16:43 AM »
Follow the photos. I hope this helps.
Bob   A link to this PDF file  http://www.stunthanger.com/uploads/bellcrank%201.pdf  Also can be viewed on the TIPS PAGE.
« Last Edit: December 11, 2006, 04:50:42 PM by Robert Storick »
Offline Richard Grogan
Re: Bellcrank bushing leadouts- step by step
« Reply #1 on: December 06, 2006, 10:36:58 AM »
Good job Bob!
Long Live the CL Crowd!
                  AMA 85745
Offline Lee Thiel
« Reply #2 on: December 06, 2006, 06:50:03 PM »
Wow, thats something even us okies can understand. y1 Thanks Bob
Lee TGD
AMA791773CD
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
« Reply #3 on: December 06, 2006, 07:15:55 PM »
Even a misplaced Okie.  Very clearly done, I think even I could follow those instructions!  Thank you from MN, too.
--Ray
--Ray
AMA902472
Offline Jim Oliver
« Reply #4 on: December 06, 2006, 08:01:52 PM »
Very good show and tell!!
When I wrap the leadouts at the wingtip, I use RED heat shrink on the UP line and BLACK on the DOWN line.
Cheers,
Jim
Jim Oliver
AMA 18475
Offline Tom Dugan
« Reply #5 on: December 06, 2006, 08:56:40 PM »
Bob,
What a great thread!!  Thanks for the time and effort.  Robert should post this in the Building Tips section of the main page.
Offline Keith Spriggs
    • khspriggs
« Reply #6 on: December 07, 2006, 12:24:26 AM »
Lee TGD
It is better than you think. Your neighbor to the north in Kansas can even understand it. Bob you did great.
Offline Glen Wearden
« Reply #7 on: December 07, 2006, 01:02:27 AM »
I just saved the photos to "My Pictures".  Thanks.........Glen
Glen Wearden
Offline Vincent Corwell
« Reply #8 on: December 07, 2006, 03:06:29 AM »
Sheer perfection,
thank you for posting this
Vincent
Offline Ron Merrill
« Reply #9 on: December 07, 2006, 12:32:45 PM »
This is what i like, follow the bounceing ball. Thanks Ron. AP^
Offline roger gebhart
« Reply #10 on: December 10, 2006, 04:04:56 PM »
Outstanding. Even I can do that.
Offline Leester
« Reply #11 on: December 10, 2006, 05:10:58 PM »
Those are the exact photos I go by since you first showed them in 04 (first that I saw). Great stuff then and now.
Leester
ama 830538
Offline rustler
« Reply #12 on: December 14, 2006, 02:49:25 AM »
Is this really all that holds it? Just one wind down and one wind back, twist together, (do we twist two copper ends or one copper and one leadout wire) turn the end over and cover with heat shrink? We don't even work some epoxy into the windings?
Ian Russell.
Offline Bob Johnson
« Reply #13 on: December 15, 2006, 07:30:13 AM »
    Yes, that is all you need. You twist the ends of the copper wire together and trim. A smear of epoxy can be added but is not necessary, some people even advise against it. Never solder the conection.
     I have found that once the copper tube is bent with the wire inside, it is extreamly difficult to pull the wire back out. Remember, this is 1/16 in. copper tubing and there is little play between the .27 leadout wire and the tube walls. Slippage will not be a problem and very little strain will be placed on the bindings. Hope this clears that up.
Bob
« Reply #14 on: December 21, 2006, 11:29:02 PM »
Being lazy, I saved all the pics by just saving the .pdf file...then it's all in one place. 2.2mb, I think.  LL~
Regarding Rustler's question...copper wire and stainless cable really grab onto eachother. "Galling", I suppose. Try starting your binding, wrap about 3 or 4 times (tightly, now!) around the cable strands, and try to slide the wire down the loop to make it tighter to the eyelet. Just about can't be done! No epoxy, no solder for sure. Heat shrink tubing is perfect for the job.  :! Steve
« Reply #15 on: December 22, 2006, 01:28:56 AM »
Hi Bob,
Outstanding!  You are very adept at picturing, explaining, and DOING these tips.  y1
Bill <><
