  • July 08, 2025, 09:30:29 PM
Author Topic: Bellcrank and leadouts  (Read 4215 times)
Offline Richard Logston
« on: April 17, 2014, 10:34:26 AM »
I am finishing up a 38 Special profile version to be powered by a .40 OS max engine. Question, I have a 4 inch black plastic bellcrank ( actually looks like carbon). What would be the best way to attach the lead outs? Should I use a small tube for the wire to bear on or can I just thread the wire through the original size hole without it cutting into the bellcrank in service. I have been out of C/L since the middle sixties, but have built several c/l airplanes in the last three years. But have only flown two flights since getting back.
Re: Bellcrank and leadouts
« Reply #1 on: April 17, 2014, 10:43:21 AM »
Hi Richard,
The tubing route is a great way of doing the lead outs, connecting them to the BC.  That is the way I do all of mine bigger than 1/2A.
BIG Bear
RNMM/AMM
« Reply #2 on: April 17, 2014, 11:27:15 AM »
Tubing.  Even if you have to open up the holes a bit.
I use 3/32" OD tubing from the hobby shop.  There are folks who have found smaller tubing, which would work better, but I don't know where to get it (McMaster-Carr?).
Here's how I did it on my last plane.  Everything worked well, except the part about forgetting to thread the control system through the wing first, and thus having to unwrap the ends, thread on the leadout guide, and rewrap.
http://stunthanger.com/smf/index.php?topic=27915.msg273968#msg273968
« Reply #3 on: April 17, 2014, 03:02:03 PM »
Thanks for your replies. Much help.
Offline 55chevr
« Reply #4 on: April 17, 2014, 04:54:02 PM »
Yup,  McMaster Carr
Joe Daly
Offline Allan Perret
  • Proverbs
« Reply #5 on: April 17, 2014, 06:08:12 PM »
K&S has 1/16" tubing in brass, copper, or aluminum.  I use the copper, the ID is just big enough to use .027" lead outs.  Don't know if you can get .032" lead outs thru it, but the .027" still has breaking strength of 125#.
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #6 on: April 17, 2014, 07:39:07 PM »
I also use the K&S 1/16 brass tubing and 135# test cable. It mikes at about .030. I get it at a good fishing store in a small spool, normally used for salt water leader material. Just for fun, anybody know who K and S are??
Offline Dick Pacini
« Reply #7 on: April 17, 2014, 09:17:00 PM »
AMA 62221
« Reply #8 on: April 19, 2014, 09:50:31 AM »
Most likely named for the owners... like Ken and Sam  (maybe?)
« Reply #9 on: April 19, 2014, 07:15:56 PM »
Not even close, try again.
« Reply #10 on: April 21, 2014, 11:50:26 AM »
A couple of guys from the Chicago area who were well known free flight modelers late 30's and 40's era. Wally Simmers of Gollywock and Jabberwock fame and Joe Konefes of Buzzard Bombshell fame. Ya gotta be an old old timer to know trivia like this!
« Last Edit: April 29, 2014, 10:22:52 AM by Don Hutchinson AMA5402 »
« Reply #11 on: May 20, 2014, 04:38:17 PM »
Rich,
With the 38 Special as the leadouts are coming through the fuse be careful to bring the ends of the tubing into a tear drop shape and make the fuse holes large enough to have a little wiggle room around where the leadouts come through.
Best,       DennisT
